Cannot get a good blue colour (CMYK) on Canon CLC 3220 digital printer
  • abbeypress Oct 23, 2008
    Where is the solution?
    Hard to understand solution because of spelling issues
    All cartridges changed on a regular basis
    Sergeant:
    Champion:
  • 331 Answers
The page  might not be getting a good  blue  bilitycolor  because of the inavailability  ofhe blue color
the bules may be gtetting finished.
try to get a new cartridge
Posted on Oct 23, 2008
    Master:
  • 538 Answers
Can you do a test page, and report the results here_ also, how old are the printer modules?
  • A Womans Computer Man
    A Womans Computer Man Oct 23, 2008
    we are assessing the situation. Can you respond with the test page answer, please..this sort of situation requires a multiple step assessment..
Why are my pictures too purple
Because printers use 4 color of inks: Cyan (blue) - Magenta (red) - Yellow and black (CMYK). If the picture is purple (which is just blue+red) then you probably need to replace the empty yellow. Check the black while you're at it since that is the one that gets used a lot. Always have spare cartridges handy for back up.
Aug 09, 2014 | Canon PIXMA Office Equipment & Supplies
Grievance
Do the colour prints when printing RGB look all right?
If so, the printer is working.
What sort of CMYK are you trying to print? CMYK EPS prints, maybe?
If so, the the fault is one of not using the correct software; the printer is working, it is just not interpreting the encapsulated PostScript to reproduce a CMYK image. Use different software capable of reading CMYK EPS files. Photoshop is one such piece of software.
Dec 12, 2013 | Office Equipment & Supplies
Error code 000804-004
www.digitalcopiersolutions.com/clc-3220.html
Color Copier Canon ImageRunner C3220, Canon's true definition of multifunction has been met. should find all on here x
Mar 14, 2013 | Canon imageRUNNER C3220 Color Copier
Canon clc 3220 E000002-0010
try to reset the error just enter the simulation program press *- 2,8(simultaniously)-* select copier- select function- select clear- select error- press ok then turn off/on the machine
Nov 19, 2010 | Canon IMAGERUNNER 6570 Copier
What does it mean when it says change k cartridge
There should be four ink cartridges inside the printer: Cyan, Magenta, Yellow and blacK.
While monitors build colours out of three emissive (active) base colours, red, green and blue, printers usually build them out of four absorbing (passive) inks, so-called CMYK. The black is referred to by its last letter to avoid confusion with Blue.
On most printers, since they usually print in black ink over white paper (and black is used to darken all other colours), the K cartridge is either bigger than the others, or needs to be replaced more often.
Mar 31, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hi, can you please tell me what error code E000751-1301 is on a canon clc 3220, thanks Jane
E751, 1301 means there is an issue with the toner system. The machine is checking for the presence of toner. After 3 attempts the machine will go into the error. In this case, the yellow toner tube needed to be replaced even though the machine did not indicate to do so. The color that is causing the issue is the first digit in the sub code.
Oct 13, 2009 | Canon CLC 1150 Color Copier
Problem in Color management settings for Canon CLC 900
thes machine are very old and outdated and will not function with up dated software but do a graduation adjust then do a calibarition with your firey that should get the colors back to canon spects, if you still hace the broblem then your software is not compatable
Nov 27, 2008 | Canon CLC-700 Copier
Canon Copier CLC 900 problems color management settings
you can buy manuals for little money from canon.com. Cheers Thomas
Canon CLC 1180 Copier / Digital Colour Printer Print Spreads
hi im jules_09 service manual are not given to clients because its a secret company keeps only there service enginer can avail to it.but if the colore spreads out check your developer or the entrance of each developer somtimes it the developer leak out specially if the developer seal is deffective
Oct 03, 2007 | Canon CLC 1120 Color Copier
41 people viewed this question
jasbo
jasbo
