Question about Canon Rebel XT / EOS 350D Digital Camera
My camera is showing error cf, what I need to do
  • 489 Answers
Hi
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins? If so you need to replace the CF reader.
If you can solder really really well you can replace it yourself, we have the part available in our store (Google: Darntoothysam) Im sure Canon will want $200+ for the repair, and we are not currently offering to do the repair for customers, sorry.
Good luck from Darntoothysam com
Thomas
Posted on Nov 01, 2008
My canon 1ds cannot read the file in the cf card.
There will be a special process you need to follow to get the camera to update the firmware. There should be a "README" file with the file.
The process may involve putting the card in the camera with the camera off, and pressing a specific button while turning it on.
The file may be "zipped", and need unzipping before putting it in the camera.
Jul 15, 2015 | Canon Cameras
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Initialize memory card in fuji s602 digital camera
install the card, turn the camera on, go into the menu and find format. It will tell you that when you format you will also erase the contents of the SD card. Click yes and format the card. Thats it. Joe
May 03, 2010 | Fuji FinePix S602 Zoom Digital Camera
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error CHR in D70s
try another cf card first. if the trouble is still the same,  there is an internal malfunction in the unit, you need pro fix then.. [:0(
Oct 11, 2007 | Nikon D70s Body Only Digital Camera
Memory Card Problem
Try to use the CF in another camera to find out whether your problem is the CF or the camera. Good luck!
Dec 21, 2006 | Canon PowerShot S410 / IXUS 430 Digital...
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
