Question about Dell Inspiron XPS M140 Notebook
No power hello gooday! my problem with my dell xps m140 it wont start anymore no power at all.. i did check the battery the power cord still wont start.. can you please help me thanks in advance den
  • 68 Answers
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Posted on Oct 31, 2008
Need to reset the bios password on my dell xps m140 laptop.
You would have to reset the whole bios to default which maybe something you cannot do. The only other method would would be to take the laptop apart and remove the battery that keeps the motherboard BIOS memory powered. It should look like a large watch battery. Remove for 5 to 10 seconds, and replace. Then put the laptop back together and that should reset the BIOS, password and all.
Apr 27, 2011 | Dell Inspiron XPS M140 Notebook
Dell xps m140 press the power button green lights come on then go off nothing ever comes on screen
dead motherboard or power supply or powercord and or battery try another power cord if nothing take out battery and try to start with out battery if neither works then it will need either a motherboard or power supply
Oct 17, 2010 | Dell Inspiron XPS M140 Notebook
My Dell XPS M140 has gone thru 3 power supply/cords in the last 2 months. With a new supply it just makes a loud hum.
try upgrading your power supply, if you're burning through them then theres a good chance that your power demand is higher then the cords are rated for. Replacing a power supply is quite simple as long as you ground yourself to something metal to make sure you don't manage to accidentally discharge static into your mobo. Also make sure that you're at least somewhat comfortable performing this task if not then id personally advise that you find someone who will
Feb 06, 2010 | Dell Inspiron XPS M140 Notebook
The screen resolution on my Dell XPS M140 changes dramatically when on battery power. It's like everything becomes overly whitewashed and bright (so much so I can't use my laptop unless it's plugged in)....
Unfortunately, this is not a fix that you can actually do yourself. The actual battery circuit is not functioning correctly.
The transformer is supposed to regulate the amount of power running to the components, it is working, but only on AC.
It does need to be taken in for repair.
Sep 13, 2009 | Dell Inspiron XPS M140 Notebook
Xps m140 want higher resolution displayed tonew secondary monitor
Notebooks usually don't have high res . They trade off the high resulation  for the small size and less power consumption.
Mar 07, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS M140 Notebook Logo
393 people viewed this question
Alun Cox
