Question about Nike Air Max+ 2009 Trainer Shoes for Men
What's your problem?how ca n i fix a minor hole on the top front part of my sneaker?
    Guru:
  • 170 Answers
Contact with www.nike.com,
they will help u best in this matter.
Posted on Mar 14, 2014
    New Friend:
You can visit this site air max 2013
Posted on Sep 15, 2013
My washer shows on the display F35, and now I'm getting sud. What must I do to fix this error.
Hi, the error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It costs about $99 to order from Sears although they are on backlog, or you can get it cheaper somewhere else. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected. Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires & 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor...
Jul 13, 2011 | Kenmore Elite 45986 Front Load Washer
My JVC CA-hvd7 is showing 'protect' and I can't
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jun 28, 2011 | JVC Audio Players & Recorders
I was drying a pair of sneakers and the drum stopped turning and won't turn after several attempts to re-start the dryer.
What happened is the belt came off. Don\'t panic! I can help. Unplug the dryer and pt it on a tailgate. You gotta oil the rollers and clean out the lint so get it somewhere you can **** dat puppy. You gotta yank out the filter and remove those 2 screws on top the filter housing. Then use a putty knife to pop the top. Yank up on the front (after removing screws) and get it out yer way. I have here an old school manual and some repair pics babe. with any luck you should have this bad baby up and running!!
MANUAL
PICTURES
Dec 18, 2009 | Kenmore 64742 Electric Dryer
The drum on dryer is off balance & making lots of noise can i fix it quick
its probably not the drum it is the bearing in the rear, easy fix if you know how, open the top remove the screws holing the front on, plus a little yellow plastic piece on the top center, remove the front, take out the 3 screws located in the back center of the drum then follow the instructions that come with the new part for bearing replacement
Aug 11, 2009 | Frigidaire Dryers
Loose fins- How do we tighten them or can't you
You'll have to pop the top of the dryer. Insert a stiff putty knife into the split between the top & front, about 2 - 3 inches in from the side. There will be a spring catch you need to push in, about 1/2 inch. There is one on each side. Stand the lid up and HOPEFULLY, the fins are held in with screws or bolts. Just tighten them. If they're rivited in, you'll have to use an epoxy putty to lock them into place. Sneakers in a dryer, without a few towels will knock them loose.
May 25, 2009 | Maytag Dryers
Nike Air Max+ 2009 Trainer Shoes for Men Logo
131 people viewed this question
Top Nike Clothing Accessories Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Andrew Taylor
Andrew Taylor
Are you a Nike Clothing Accessory Expert? Answer questions, earn points and help others
