Question about Directed OHD1021 Car Video Player
No remote for directed car dvd player - Directed OHD1021 Car Video Player
I have an apex uk1a remote need remote code for apex pd 510 portable dvd/cd mp3 player
Code, if applicable, will be in the remote. If your Apex remote is compatible with your Apex player, you should be able to control it directly just by pressing DVD and the power button.
Aug 20, 2016 | Apex Digital Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Can you find codes for 8 device remote control for polaroid dvd player
Codes are stored in the remote. If you are using a Polaroid remote with a Polaroid DVD player, you should be able to use it directly.
Nov 06, 2015 | Polaroid Televison & Video
Cant get my akai DVD player to play all my cds and dvds
Instructions
  1. Changing Region Code on Oppo and Similar DVD Players
    • 1
      Press the "On" button on the remote control to turn on the DVD player.
    • 2
      Press the "Setup" button on the remote control.
    • 3
      Press the following buttons in this precise order: 9210.
    • 4
      Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
    • 5
      Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
    Changing Region Code on Sony and Similar DVD Players
    • 6
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
    • 7
      Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
    • 8
      Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
    • 9
      Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
    • 10
      Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
    Changing Region Code on Denon and Similar DVD Players
    • 11
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
    • 12
    • 13
    • 14
    • 15
      Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
Apr 04, 2013 | Akai Dv-px6150k - Multi Region...
Memorex Dvd Remote Codes
Hello
Setup codes for Memorex DVD with Direct TV [TC RC32] universal remote are>
20695, 20831, 21270
OK.
Oct 31, 2011 | Memorex MVD2022 DVD Player
I just installed a Directed OHD700 Car DVD Player. Audio works fine but no picture. just white screen. What can be wrong?
Some in car dvd players wont play on screen with car turned on. I wired a switch to the remote line to bypass. Wiring is defintly the issue
Mar 24, 2010 | Directed OHD700 Car DVD Player
My remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
Nov 15, 2009 | RCA RCU300WBL Remote Control
Universal remote
I found a perfect universal remote with the logitech harmony 525. usb / infrared / internet upgradeable. also loads keyfunctions directly from the old remote, but most of the keys came directly from the standards offered. the configuration is web-based and always up2date. service people are also very helpful. can fully recommend it!
Jun 26, 2007 | Yamakawa DVD-218 DVD Player
Directed OHD1021 Car Video Player Logo
55 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
