Bosch washing m/c wf2000 pump not working
Pump not working,will not empty water
  • 11tommy Oct 23, 2008
    We have a Maytag Neptune washing machine that will not drain water whenever a normal load of clothes are washed. We can get it to drain water if the load is very light. Any suggestions?
  • 903 Answers
It may be as simple as a blocked pipe. Check the outlet under the sink it may be full of hair/fluff etc. If you can disconnect the outflow pipe from the u-bend under the sink, first check that the end of the outflow pipe is not blocked, then check the u-bend for blockages. If these are both clear then the pump itself may have a blockage. If you know how to get to the pump, then ask someone to help you take the outflow pipe away from the pump so you can check the pump and pipe for blockages. Be prepared for plenty of gushing water if you remove the pipe away from the pump, and have a pot or something ready under the sink for when you check the pipe at that end. I hope this helps.
Posted on Oct 23, 2008
Noisy pump on bosch 300 series washer
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Aug 19, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have an Bosch washing machine, model WFMC6400UC 12391301. I get the drain blocked Fault notice on the control panel.I have opened the cover and observed the pump working, I have blown out the discharge...
Bosch washing machine, model WFMC6400UC 12391301 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 31, 2011 | Bosch Nexxt300 WFMC220 Front Load Washer
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hi, Bosch WAS28720FF/01 Washing machine sometimes empties and sometimes does not. "Pump blocked" is the typical error message. Pump and drain tube have been inspected and cleared, and there is...
Bosch WAS28720FF/01 Washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Jan 01, 2011 | Bosch Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
Will not empty the water out, water pump works-pipes are clean and motor brushes are new. When the dial is constanly turned eventually it empties
That's odd.
When you say the pump works, I assume you mean you can see it turning?
When you say the pipes are clean, I assume you mean the washing machine's pipes.
Motor brushes? Well, if you can see the pump turning, maybe that's irrelevant.
I'm stumped. Are you sure the pump is turning? Is the impeller connected to the drive shaft? Is the pump belt driven?
Lastly, are you sure your sewage system takes enough water?
Sorry I couldn't be more helpful.
Jul 01, 2008 | Bosch Washing Machines
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
