Question about Akai PT5492S 54" Rear Projection Television
Pt5492s manual tv is staying in sleep mode.
What is the sleep mode?
To know more about the sleep mode and its adjustment, refer its user manual. It is a mode that you can set the sleep time, after which the TV will turn Off when that time is reached; after 30 min, iHr, 2Hr or so, to which that time is set for. http://electrohelponline.blogspot.com/
Jul 06, 2014 | Proscan Televison & Video
Sony trinitron tv is in sleep mode how do i turn sleep mode off
Check this link and download the user manual to your TV. Refer it. It have all details.
Feb 06, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv stays in sleep mode how to restore it?
Try to press a sleep mode again to resume..
Aug 28, 2012 | Polaroid Televison & Video
Before while watching TV a message comes up saying it will go into sleep mode, now it doesnt have a picture screen at all
depending on the model number set is not making it full on--something is causing the set to shutdown for protection.
Apr 09, 2012 | Televison & Video
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Red light comes on but nothing else
I AM HAVING TROUBLE GETTING A PICTURE OR SOUND ON MY TV THE RED LIGHT STAYS ON BUT NOTHNG ELSE, WHAT DO YOU THINK I SOULD DO, IS THERE SOMEWERER AN INTERNET SITE OR STORE THAT I CAN BUY THE MANUAL TO TRY TO FIX THE PROBLEM BEFORE CALLING THE REPAI MAN?
Aug 23, 2008 | Akai PT5492S 54" Rear Projection...
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Akai PT5492S 54" Rear Projection Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
