Question about Intermec CK31 Portable Terminal
Intermec CK31 hangs after cold booting screen
Performed both a cold and warm reboot. Even removed battery and depressed the rest button for 20 secs. The Cold booting screen appears, and then an hour glass on a blank screen which does not progress past this point.
4 Suggested Answers
  • 13 Answers
SOURCE: Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Posted on Sep 09, 2008
  • 61 Answers
SOURCE: My Intermec CK31 just hangs, it scan and there is
Sounds like you could have a main logic board problem. Try restoring computer to factory defaults from the intermec settings.
Posted on Apr 05, 2009
SOURCE: Intermec CK31 the most slow terminal.. is a piece
We have come across this many many times. After the terminal has fully booted (can take an hour when slow) and if you manage to access the CPU monitor you would be able to see that the CPU is running constantly at 100% - not good.
A complete blank and operating system restore is required.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
Intermec CK31 the most slow terminal.. is a piece of ****..
or TEL 01202 620955
Nov 07, 2009 | Intermec CK31
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
helpdesk@biastechnology.com or TEL 01202 620955
Oct 29, 2009 | Intermec CK31 Portable Terminal
My Intermec CK31 just hangs, it scan and there is a sounf beeping but the touchscreen is not working and even the keyboard.
Mar 06, 2009 | Intermec CK31 Portable Terminal
Green light stuck on.
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Sep 12, 2008 | Intermec CK30
Mar 10, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 Portable Terminal Logo
108 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
