Question about Acer Aspire One AOD2501604 Netbook
No sound erased sound card
No sound
  • Acer Master
  • 32,281 Answers
Download the audio and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Posted on Feb 10, 2012
Acer aspire Z3571 wouldn't start up just gives a sharp sound. Help please.
hi!,
the continuous sound appear to have some trouble in the cpu consider the screen was totally black out the most common factor there is your memory card and video card.try to disconnect the 2 card and clean by rubbing an eraser of pencil the slotted connector of the card.if still not work replace the card one by one.hope this help you.
Nov 04, 2012 | Computers & Internet
I ERASED MY HP SOUND CARD. WHAT DO I DO?
You can't erase a sound card. It sounds like you might have uninstalled the drivers - just find them online and reinstall them.
Mar 09, 2010 | HP (400745-001) Sound Card
I have compaq presario c300 but sound driver is not installing
check if the sound card is installed firmly, clean the copper plates at the bottom with an eraser just like your erasing dirt from paper and the last solution clean your mobo and sound card.
Sep 07, 2009 | Compaq Creative Sound Blaster PCI 128...
I need a realtik sound device manager..where can i download it??
search for drivers of ur particular model on www.hp.com.
Jul 08, 2009 | Compaq Audio card Sound Card
Cant find sound folder on mini sd card to add tones from computer
This menu displays music files saved in your phone and microSD card. 1. From idle mode, press and hold the OK Key [OK] to unlock the keypad, press the Left Soft Key [Menu], the Directional Key to select “Media Gallery”, then slide out the QWERTY keyboard and press 1. My Sounds. 2. Scroll through the downloaded or saved sounds to select the sound and press the OK Key [PLAY] to listen to the highlighted sound. To erase the selected sound, press the Left Soft Key [Erase], then press the Right Soft Key [Yes]. 3. Press the Right Soft Key [Options] to choose from the following: • Send by Picture Message: To send a MMS message. • Send Online Album: To upload selected sound to sound online server. • Send by Bluetooth: To send selected sound to another Bluetooth device. • Set As: Assigns the selected sound for specific tasks (Ringtone, Contact ID, Alert Tone). • Rename: Rename the selected sound. • Lock/Unlock: Select to lock or unlock the selected sound. • Move: To move the sound to another location. • Erase All: To erase all the sound files in your phone. • File Info: Displays information about the selected sound. Since you can’t Send or Move a DRM file, the Send/Move options will not appear when working with these type of files. With microSD card inserted, you can browse all folders and sound files saved in the microSD card by searching the Back folder . indicates that current file is stored in the external memory. indicates that current file is stored in the phone memory. indicates that you have sub directory for the current folder.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 02, 2009 | UTStarcom Blitz Cell Phone
Can't un-protect Images in My Canon Rebel XS
It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
When i turn my digital camera on with the memory card in it (XD M256mb) it says the card is full. I go to erase photos and it says there are no photos to erase. If i take the memory card out, i can take 15...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Jul 20, 2008 | Olympus Cameras
Ensoniq Esq1
If the old songs cannot be erased means first u tri to remove with
system machenic and than to they are not erased means clean up the entire folder try it.
Nov 04, 2007 | Creative Labs Ensonic PCI Sound Card
Acer Aspire One AOD2501604 Netbook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
