Question about Lands Phones
How to remove the stand on a meridian m3902 corded phone
Meridian M3820 - why is display not working
Try another 4 wire phone cord from the wall jack to the phone it is possible that you have a bad cord. These phones will only work with a Meridian System .2 wires are line ,the other 2 wires are power to the phone. If you have another phone try plugging it into the same wall jack to check the jack/line itself. Anything else would be a defective phone/ lcd ( note you can have dial tone without display, but the unit will only access one line.
Feb 19, 2015 | Nortel Meridian M3820 Corded Phone
Meridian 7310 - Issues
Mod cord, cable, jack or system port issue, call in your local tech/vendor to repair it.
Nov 13, 2012 | NorStar Meridian M7310 Phone
Caller id is not displaying. but displays on our other phones. date/time work, phone plugged in fine. other suggesitions? is there some type of #'s I need to put in to get it to working again?
If this is a stand alone analog(not connected to phone system) telephone, check for batteries. If the phone is connected to a phone system, the phone must be set to ring to receive caller ID. If neither suggestion helps, please send model number of phone and model number of phone system if there is one.
Jan 23, 2011 | Meridian Corded Memory Speakerphone with...
Meridian 9516cw desk phone in continuous"Please wait"preboot mode
Same issue. One day I walk in my den and the phone is at Please wait..., the Handsfree/Mute LED is blinking, and there's a tick TOCK sound (fainter tick when LED is off, louder TOCK when the LED is on). Tried unplugging for hours, 'raking' the buttons, unplugging all cords. It is fairly old and perhaps the logic board has failed.
Oct 16, 2009 | NorStar Meridian 8314 Corded Phone
I want to insert headphone jack and need to
There should be a swing plastic cover on the front underside of the phone for plugging in the headphones line cord plugged in and handset cord plugged in the middle jack is for heanset.
Oct 05, 2009 | Nortel Meridian M3820 Corded Phone
Cannot dial out on my Meridian 9516 telephone
Is the Program button on . If it is turn it off. You can also try resetting the phone by unplugging the silver line cord from the phone or the wall jack and then replugging it after about 10 seconds.
see if that works
Sep 03, 2009 | Meridian Two-Line Corded Business phone
Irritation
Contact Nortel since they make meridian systems and see what the problem is. It could be the plastics, the dye, something in the heaser, or some residue casuing an elergic reaction.
Some meridian phones allow for a headset to be installed at the bottom of the phone. The headet jack should be labeled on the botton of the phone if you have one. That could solve the problem as well.
Jul 31, 2008 | Astra Meridian 9417 Corded Phone
Lands Phones Logo
240 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
