How to install cmoss battery in g4 ibook 1134
  • 536 Answers
The problem that you are experiencing is not a CMOS battery issue, because it doesn't have a CMOS battery.
What may be necessary is that you reset the PMU by following these directions: http://support.apple.com/kb/HT1431
Please read the entire article before resetting your PMU and follow all the directions there.
Posted on Feb 10, 2012
  • 22 Answers
SOURCE: ibook G4 14" 1.4mhz
On an Apple system, this is an indication that it thinks there is little or no battery left and goes to sleep to protect data loss. Your battery might be going bad (showing a full charge, but lasting for only a few minutes) or there may be a problem with your power supply.
Posted on Nov 14, 2007
  • 33 Answers
SOURCE: IBOOK G4
Have you looked at disk #2 to make sure no scratches or sticky fingerprints?? Usually when you get an error on 2nd media its issues with this and or when you boot to fist disk goto utilities and check the hard dirve to see if its not failing at a point also make sure your doing a full restore and not archieve install
Posted on Nov 16, 2008
seaniepie
  • 250 Answers
SOURCE: ibook g4 12" 800mghz freezes alot, especially when bairly moved
Hi Robert
Try a reset of the PMU, instructions here:
http://support.apple.com/kb/HT1431?viewlocale=en_US
All the best
Sean
PiDigital
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: apple ibook g4 ejects every movie i put in and will not play
Reinstall the operating system.
Posted on Feb 18, 2009
kklare
  • 85 Answers
SOURCE: how to sync an IBook G4 wth a Mac 1 Ghz Power PC G4
Transferring you iPhoto Library requires the same version of iPhoto on each. Then you can just move the "package" from one to the other. It appears as a package in the latest versions but inside is a directory hierarchy. Older versions used the file system for this. The package keeps you from messing with the files and internal links. Depending on your collection you may need a real disk and not just a flash drive.
To transfer the photos themselves only requires exporting from one machine and importing on the other. However, you then lose any comments, folders, and anything but the photos. You may want to be sure to send the copy with red-eye correction... or you will have to do it again. Do it a folder at a time. -Ken
Posted on Oct 04, 2009
Testimonial: "Really good advice which I have followed-many thanks."
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
Jun 25, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Reset_To_Factory_Setting on mac ibook g4
Justin I suppose the easiest way to do this would be to insert your system disk into your ibook boot it up holding down the c key on your keyboard and then instal a fresh system. Use the erase and instal option as this will erase your hard drive. Any other queries get back to me, hope this helps. By the way a step by step way of doing this can be found at http://macs.about.com/od/leopard105/ss/installleopard.htm although it's leopard it should be similar across system.
Oct 31, 2011 | Apple iBook G4 Mac Notebook
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
IBook G4 shows picture of mouse needing batteries
It sounds like your internal trackpad isn't working, and it is currently asking you to hook up a mouse, be it thru Bluetooth or USB - have you tried a USB mouse on it to see what happens?
Oct 30, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
When i turn my ibook g4 on, it asks me for a password. ive never installed one. is there a default password i can use?
for resetting the admin password w/out cd.
It's amazing the things you'll find with a search engine.
Mar 25, 2009 | Apple iBook G4 Mac Notebook
How to replace clock battery of ibook G4 laptop
Replace the on board capacitor with a Panasonic Capacitor 5.5V 0.22F Model number:EECS0HD224H cost about $3 . You will need to desoldier and soldier the new one on, it's easy even for a novice.
It is a kind of on board battery contrary to what most idiot mac users say as a battery IS a form of Capacitor.
Feb 12, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My laptop ibook G4 power button is not functioning even if press
have you got it plugged in too charger, power button wont function if no charge in battery..... easy to forget when your freaking out about your 3k lap top... goodluck Chas
Jan 31, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Memory upgrade for ibook g4
Hi-
you can check a lot of sites where you can view and check onthe step by step guides how to install or upgrade the memory of your ibook, check this links
http://www.memorystock.com/memory/AppleiBookG412GHzM9419LLAMemory.html
http://www.edgetechcorp.com/memory/apple-ibook-g4-memory.asp
http://www.powerbookmedic.com/Take-Apart-Repair-Manuals-p-1-c-258.html
just select the type of memory card that you are using and it will lead you to a page where you can download a pdf file of the instruction.
Hope this helps, pls rate as fixya if it helps. thanks!!
Jun 26, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
