Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
CD drive door is jammed - Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
  • Dell Master
  • 32,281 Answers
There is a tiny hole just below thr CD drive tray. Straighten a paper clip and insert it into this hole and gently push the paper clip until the drive tray pops out. You can then pull the tray out to the fully opened position.
Posted on Feb 10, 2012
Cd door will not open
If cd stuck and jamming, very very gentle use thin screwdriver or similar, and prise open. Be gentle.
if no cd, sounds like drive band may be broken, requiring replacement?
Nov 16, 2014 | Audio Players & Recorders
How do I get a cd that is jammed into a cdrom drive out when the drive will open.
there is a little hole in the cdrom\'s door.....prick it with a pin and the cd will come out
Oct 15, 2014 | Gateway Computers & Internet
CD DRIVE DOOR BUTTON JAMMED ON AX5900
You should see a small 'pin hole' on the face of the CD drive, usually near the eject button itself, but not always. Straighten a paper clip (med size is best) and insert into the hole. You will feel a little resistance (this is good) continue pushing the paper clip straight in until the door pops open. Almost all CD/DVD drives have this "manual open" pin hole for just such cases. Alternately you can open My Computer, point to the CD/DVD icon, right click and choose the "eject" option, this will open the tray if the physical button has stopped working.
Jul 15, 2014 | Acer Computers & Internet
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
Cdn-24 cd door wont open
Often the cause is a jammed CD or aa little belt that drives the carriage has failed or is slipping.
You need the OPEN the case to retrieve the CD if one is in there and check the mechanism does not have a problem. Some drives used to have a SMALL hole near the door that one would insert a straightened paper clip into straight to press a release... You might check for that.
Feb 25, 2011 | Numark CDn25 Professional DJ CD Player
Drive light flashes and door will not open
Try to insert a pin in the small hole and it will open up. The door is probably jam and doing this will open it.
Jul 02, 2010 | TDK veloCD CD-RW Burner
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
Solve a jammed cd problem
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Jan 31, 2010 | Onkyo DX-RD511 CD Player
Can't get the disc out...
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Mar 08, 2009 | LG GCE 8523BB (GCE-8523BB-10PK) CD-RW...
Drive door jammed on emachines e4212
straighten out a paper clip and locate a small hole on the front of the drive, push the paperclip in the hold and the cd\dvd will come out. If might start working after this but chances are that if it does you will need a new one in teh near future.
Nov 19, 2008 | Computers & Internet
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
