GE front load washer E39 error code
When I try and run a wash cycle the unit starts as normal, locks door, spins a bit and when it is time to dispence the detergent it will time out and never start the cycle. I keep getting error E39, dispenser time out. I have preformed every function in test mode and everything works as it should but when I run a wash cycle... E39 What now?????
  • ECA2099
    ECA2099 Oct 19, 2013
    Greg - did you ever received a response? where you able to fix it? I have the exact same problem with model GFWN1000LWW GE Washer Front Loading .
SOURCE: Detergent not being washed out of dispenser
Try a new box of detergent. Sometimes a batch of detergent just isn't right.
Posted on Apr 27, 2007
aborcass
  • 2651 Answers
SOURCE: No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Posted on Feb 23, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 58 Answers
SOURCE: Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Posted on Jan 10, 2009
  • 100 Answers
SOURCE: Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Posted on Feb 03, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
Front load GE Adora washer isn't spinning when it should. Other sites I see they talk about replacing the door lock assembly...what else could it be?
I had the same problem with my front load (different model). The pump was not pumping out the water, thus stopping or slowing the spin. Take off your pump (located under the washer in the front right on my model) and look inside to see if there is any junk stopping the plastic spinner to spin. Clean out really good along with the attached hoses. Replace (tricky!) and try the washer! I had lots of junk in the pump along with a few hairpins that stopped the sinner in the pump. This is a tricky process on my model.
Mar 28, 2010 | GE WSXH208A Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Troubleshooting your problem LG Washer
you may find that you need to dismantle the pump as you can get things inside the impellor area causing intermitant problem
May 30, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
384 people viewed this question
Top Washing Machines Experts
