Question about Technics SL-1200 Turntable
SL-1200MK2 SOUND ON ONLY ONE SIDE..
Hi
I´ve problem with my sl-1200mk2 thats I only have sound from one side. LH is working just fine but RH is not any sound at all.
  • jonas_sweden Oct 23, 2008
    Thanks,
    problem solved..
    The problem var one of the signal cable var broken inside (no wear on the out side). I changed both the cables and now it´s like new
    BUT when i had take the "undercover" off. A small metal ball fall out when I turn the player, it´s about 2-3mm in dia. I did not find any place for it.. hope you understand what i mean....
    Do I need this part? Its playing just fine right now
More than likely this metal ball is the one that is used with the on/off switch.
Posted on Nov 06, 2008
  • 899 Answers
This is a broken connection or a bad transistor output , but it will need to be tested to determine the cause or causes
hope you find this helpful
and plz rate my help, and if you need more help just let me know!
electech
Posted on Oct 23, 2008
  • jason Oct 24, 2008
    yes that metal ball went under the turn table wheel and it is part of the barrings that the turn table uses to sspin evenly and smooth , you might want to make sure more have not come out or that the clip that holds the turntable down is secure
    electech
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Turntable technics sl d93 when arm in ready to
hi, there is a rubber grommet at the base of the tonearm on the left side. Remove and insert a flat blade screw driver. Adjust and test until remedied. Cheers John. Stylus City.
Jan 10, 2011 | Technics SL-1200MK2 Turntable
Fried power on technics SL 1200MK2.
If you are lucky then just the fuse may have failed - usually F1 / 250mA / 20mm type.
If your unlucky the transformer may have fried - mail me for a price mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
May 18, 2010 | Technics SL-1200MK2 Turntable
I have sl-1200mk2, and the signal does not come in
The first thing to is try to eliminate the cartridge as a cause of the fault. You can do this by swapping the connections around on the cartridge. If you get the weakness still on the Red cable you know it is that. Solder joints do cause trouble, often the earth is the problem. Try resoldering the joints. Or replace the entire cable as there might be a break.
May 14, 2010 | Technics SL-1200MK2 Turntable
Sl 1200 mk2 no sound comming out new needle
It sounds like the rca (phono) leads also check your cartridge.
Regards.
http://www.audiovisualservices.info/
Dec 16, 2008 | Technics SL-1200MK2 Turntable
Technics sl-1200mk2, schematic
Hi - You can download the manual by clicking the link underlined in blue below:
sl-1200mk2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 04, 2008 | Technics Audio Players & Recorders
Technics SL-1200 Turntable Logo
169 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
