How to replace cmoss battery in g4laptop 1134
    Top Expert:
  • Computers & ... Master
  • 75,169 Answers
Hello
The CMOS battery is one that energises the Bios IC, when we switch OFF the system, to retain the previous status in its memeory. To replace it, you have to open the sytem. It can be located very near to the BIOS IC. A lithium disc button type battery, have 3Volts can be located inserted in a small cage. You cantake it out, and place an other battery of same type. But when you take out this abttery, all the settings of the BIOS IC will be resetted to its orginal factory settings, including date and time. You have to readjust all the Bios settings, after replacing the new battery.
So it will be best to note down all the present Bios settings, and write it on a piece of paper, before replacing this battery. OK.
Posted on Feb 10, 2012
Admin pasword
to reset the password to blank take out the battery on the motherboard . then put it back in and reboot
May 15, 2014 | Intel Motherboard 2.2ghz E210882 Has Cpu,...
How to install cmoss battery in g4 ibook 1134
The problem that you are experiencing is not a CMOS battery issue, because it doesn't have a CMOS battery.
What may be necessary is that you reset the PMU by following these directions: http://support.apple.com/kb/HT1431
Please read the entire article before resetting your PMU and follow all the directions there.
Feb 09, 2012 | Computers & Internet
How do I change cmoss battery? THNX
The cmos battery is usually a dime shaped battery located on the motherboard inside the computer. It is normally just held in place by a small piece of metal that is under pressure. Open the pc and locate the battery. The location on the motherboard will vary depending on the manufacturer. Use a small screwdriver to release the pressure on the metal piece and the battery should pop out. Always replace with the same model of battery, it will be written on the top of it.
Jul 07, 2011 | Computers & Internet
The Actron code read code 1134, but my code book have not this code, would you can assist me Thank Manuel Corrales CR
1134 is just saying the Os sensor is switching slower than the ECM is programmed to see-it probably is due to be replaced since the car is 10 years old now. It is your Bank 1 Side 1 sensor, the one in front of the catalytic converter. You can try disconnecting the negative battery cable to see if it comes back, but you will probably just end up replacing it anyway, they get a coating on them over the years and replacing it will actually improve mileage and it will probably feel like it runs better too. Less than $50, and not too difficult to replace.
Apr 19, 2011 | 2001 Hyundai Elantra
How to reset cmoss password in toshiba satelite A135-S2276 service manual
You can try some BIOS hacks, just google them. Or you can try and take your laptop apart (use the manual), locate the BIOS battery, take it out and leave it for 5-10 minutes and the password should be reset either to default or nothing.
Jan 12, 2011 | Toshiba Satellite A135-S2276 Notebook
My laptop ( hp dv5t-1000) can't start up. i try press F10 for entering to bioss configuration but it doesn't work. Please help me how to do. ( i also replace cmoss battery)
try pressing F8 and start up from there you can restore your laptop to a previous date. possibly the date when your laptop was still working.
Sep 29, 2010 | Computers & Internet
How long to reset cmoss battery
pull the cmos cell for 15 minutes then turn on the p[owe to computer for 2 times then refix cmos cell after 15 minutes then all are defaults.
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 21, 2009 | Acer TravelMate 529ATX Notebook
CDROM/CMOSS
there is problem in your cd rom, replace it
Oct 02, 2008 | Computers & Internet
IBM Thinkpad T20 CMOS Battery Replacement?
hi-- no need to take out keyboard turn over laptop and take out main battery, underneath is the cmoss battery in a yellow sleeve, it is in a black square surround with one small screw holding it in place, take out this screw and with a tiny screw driver manouvre the plastic square holding the cmoss battery out of the recess and than holding this square gentlly but firmly pull the cmoss out.beleive me it will come out, to replace just do everthing in reverse with a new cmoss battery in place.eyeball the aperture for the white connector of the cmoss and you will replace the battery.
Jun 30, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
