Question about Vizio M550NV 55 in LCD HDTV
Left half my my screen has different color bars running vertically down it
  • Vizio Master
  • 6,694 Answers
Your tv have problem with the T con board. T con board is one wich drives the pixels in the LCD panel. There is no repair possible with these boards. You have to replace the T con board. Normally you can find the t con board in the top centre or the bottom centre of the tv covered with metal cover or aluminium foil.
Here i have added the link for T con board you can fin the picture of the board in the link
Ajin
http://www.ebay.com/itm/Vizio-M550NV-T-Con-3655-0022-0147-4A-0170-2372-0024-/280719517500?pt=LH_DefaultDomain_0&hash=item415c2fe73c
Posted on Feb 10, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: P2 42HD - Picture OK on right half ... vertical bars & black on left side
I just got quoted $705 from the Vizio certified repair partner. Nice. Nice and way too expensive. I may as well buy a new TV instead. It certainly won't be a Vizio. They told me a I needed a Y systainer, C systainer and a right-driver board.
Lame. I'm trying to find something local.
Posted on May 27, 2008
  • 6 Answers
SOURCE: Have a Vizio P42HDe purchased in 2005. Right half
Bought mine in 2005 too.........just started with green (rainbow patterns in background), bad overall coloring and dark shadows on faces on the screen. 5 yr shelf life maybe!
Posted on Dec 06, 2009
freetek
  • 5568 Answers
SOURCE: left half of screen is filled with vertical
If I am right, this is an expensive problem.
The minute pixels that make up the display are turned off and on by circuits arranged in an X-Y matrix. To avoid using one circuit to control each pixel, the circuits are rapidly scanned at a rate higher than the eye can detect.
One or more of the circuits that do the scanning have failed on your set and the ugly part is, the display panels often have these mounted on the display itself forming a 'package' that speeds assembly and are made only by a few companies. If yours is one of these, the entire panel would have to be replaced since the integrated circuits used are very small and have pin spacings that pretty much preclude replacement by hand since they were originally placed by robots.
I hope for your sake the display panel and its control circuits are separate and the panel is still fine since the cost of an integrated replacement may prove to be about 1/2 to 3/4 of the cost of a new set.
Posted on Dec 12, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Panasonic TC-P65VT25 has a black vertical line half way down screen.
Sounds like you've had a failure of a part in the electronics. Plasma TVs use pretty high voltages (like the old picture-tube models) and parts can get fried over time. You'll need to have your Panasonic serviced by a qualified technician. Don't try to do it yourself -- high voltages, remember?
Nov 01, 2014 | Panasonic Televison & Video
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Left half of screen has vertical color bars of different colors
Hi
This will be your screen controller board that has failed also known as the ldv's board, With the back removed from your TV it will sit below your power supply and be connected via a ribbon cable to your Y Sustain board on the left.
Remove it and take the part number of the board then Google or Ebay for a replacement.
Take a look at the below link so you know what you are looking for.
Hope this helps
http://cgi.ebay.co.uk/LG-42-Plasma-Tv-part-LOGIC-CONTROL-Board-EAX36952701_W0QQitemZ350341474285QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5191faa7ed
Apr 21, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Oct 12, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Half my screen works
I had this, and it was just a small connection that was loose.
Dec 22, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
Nov 02, 2008 | Televison & Video
Open Questions:
See all Vizio M550NV 55 in LCD HDTV Questions
Vizio M550NV 55 in LCD HDTV Logo
988 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
