Question about Baby Lock Imagine
Please give me instructions on changing thread color in the serger
I have a baby lock imagine
  • Baby Lock Master
  • 7,365 Answers
Go to the babylock website
go to the downloads
it will bring up a menu
pick manuals--it will take you to another page
click on sergers
the babylock imagine are toward the bottom
I have a Eclipse--they are great sergers
Posted on Feb 10, 2012
trial2962
  • 107 Answers
SOURCE: Looking for an owner's manual for an Imagine serger by Baby Lock
It is onthe Baby Lock website.
Posted on Mar 16, 2010
  • 3 Answers
SOURCE: My Baby Lock Imagine Wave serger, won't thread the
The next best solution would be to hold a small white card behind the needles, so you can thereby see the holes easier for threading.
Posted on Dec 13, 2010
trial2962
  • 107 Answers
SOURCE: I have acquired an old EA-605 Baby Lock serger,
You might take a look on eBay item # 160362974035
Posted on Nov 06, 2009
SOURCE: Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Posted on Oct 28, 2008
  • 4 Answers
SOURCE: Baby Lock Serger Instruction Manual
Contact your dealer or one on-line. They'll sell anything for money. There's also a good workbook available although expensive. But worth it.
Posted on Apr 12, 2008
Baby Lock "Imagine" serger threading guide
I highly recommend you watch the videos on YouTube. They explain as they are threading the machine and the images show you exactly what to do.
Best of luck!
Aug 14, 2017 | Sewing Machines
Babylock imagine serger manual
contact babylock customer service about a manual
Jan 19, 2012 | Baby Lock Imagine
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
Oct 28, 2011 | Baby Lock Imagine
My Imagine Serger's threading ports are blowing out air when I press the lever, not sucking the thread back in.
Hello Wardmel
Make sure that the serger is set up for threading, now check that the air tubes are not plugged. You should have a long spun wire to clear the air paths.
Happy Stitching
Sewingirl/
Jun 30, 2011 | Baby Lock Imagine
Baby lock Imagine Serger - Can anyone tell me how to fix this problem. The force air threader (looper) will not push the thread all the way through
I "THINK" I have my machine threaded properly but it will not make a chain stitch. I followed the thread guide for the narrow three spool set up with the right needle setting.
why would the machine not catch the chain ????
Dec 12, 2010 | Baby Lock Imagine
I have never used a serger before and a friend is letting me use hers. There is string on the machine, but how do I put the colors I want on and get it to the needle? The machine is a Baby Lock BL3-417. ...
here's a tip I learned for sewing machine or serger
do one thread cone at a time-the cone or spool that's on the serger--cut the thread close to the cone-then remove the cone from the serger ,,don't remove the thread that you just cut from the serger,,now put your thread on the spindle & tie your thread to the thread that you just cut (make sure it's a small knot) now the thread that's in the needle pull until the thread that in the needle is your & then cut off the other thread & make sure to cut of the knot part & leave a thread tail of 4 to 6 inches
do each spindle this way
Dec 09, 2010 | Baby Lock Sewing Machines
My Baby Lock Imagine Wave serger, won't thread the right or left needles and I have been troubleshooting for over an hour.
H
likely the needle threader needs replacing or some times straightening.
Contact me at sewaway@shaw.ca
Wayne Buss
Sew-A-Way Sewing Machines
Medicine Hat Alberta
T1A 0C9 ph 403 527 7801
Apr 21, 2010 | Baby Lock Imagine
Hi..I have a babylock imagine, and trying to insert the upper looper thread and the thread won't go in all the way, no matter how hard I try, please help..Thank's
There is a wire threader that came with the serger that you can insert into the thread port to make sure the entry is not clogged with a broken thread.
I lost mine and use a length of fishing line.
Mar 18, 2010 | Baby Lock Imagine
Sewing Machines Logo
184 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
