Question about Moen Home
Push Pull Shower Valve also off in middle position
In my shower, there is a push pull knob to operate. Usually on a single knob shower, adjusting the knob to the middle should deliver equal hot and cold. However, I get no water in the middle. It's like the shower is off instead of giving a mix of hot and cold.
  • 101 Answers
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Posted on Feb 10, 2012
  • 50 Answers
SOURCE: The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Posted on Oct 11, 2009
arealplumber
  • 33 Answers
SOURCE: Can't get the cartridge out
You have a common problem with Moen cartridges. 1st if the valve is plastic these instructions may not help you, they are for brass valves. If your not afraid to spend a little money you can go to the local hardware store and ask for a Moen cartridge puller. They usually cost between $15-$100 for the good one. Get the one that looks like a tee. (see picture)
  1. First turn off the water to the valve.
  2. Screw the tool to the valve where the handle would connect to.
  3. Align the slots on the tool to the slots on the valve.
  4. Turn the valve 360 degrees several times.
  5. Pull the valve gently and firmly towards slowly increasing the pressure.
  • At this point the valve will come out and your done.
  • If just the center portion will comes out heres what you do.
  1. Remove the center portion of the valve from your tool.
  2. You will notice at the end of the tool handle is a brass ring.
  3. Slide ring down to button and depress button until it is held in place with ring.
  4. Slide this part of the tool with ring into the valve. (ring will not go in valve)
  5. Insert this into the valve all the way you can until you hear a click.
  6. Turn and gently pull until valve comes out.
  • Note: if both of these fail you need to change the valve.
Posted on Dec 05, 2008
  • 127 Answers
SOURCE: WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Posted on Jun 23, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
  • 50 Answers
SOURCE: Moen shower head drips. Single lever shower only.
Probably need to remove and replace the cartridge. Often sediment will tear part of the o-ring or seal on the cartridge and cause this problem...
varies by model, but generally, remove the cap on the knob, unscrew the knob, remove the keyed sleeve, remove the round trim plate & shut off the service stops (verify they are fully closed by pulling out on the valve stem) next remove the retaining clip (needle nose and be gentle) that holds the cartridge in place, then pull the cartridge straight out with vice grips or similar (or get a puller). clean the cartridge, flush out the valve body by slightly opening both service stops, reinstall cartridge and clip, open service stops and see if it still leaks. if it does, take your cartridge to the store (any reasonable HW or plumbing store should have a replacement) and get a new one. then reverse the process to reinstall.
If you send me the model I'll get you more specific instrucitons and pictures...
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
I have a one handle Delta shower knob. I have turned up the hot water heater. All the other sinks within a few feet of the shower run very very hot but my shower stays a mild luke no matter what. The knob...
On your single handle the first thing you do is remove the handle. To do this locate allen set screw on handle and select the right size allen wrench to fit it. Loosen set screw and pull handle out away from wall to remove it. There should be a plastic disc on the handle stem, slid it out to remove it.Remove chrome sleeve..On valve body there are marking that show hot or cold settings. Seperate teeth on geared flanges and rotate set stop toward h mark on valve body. Each tooth will change temperature about three degrees. Make trial setting and reassemble and try it out. If you want it hotter just repeat adjustments. If you try to go to far you will not be able to mesh gears,simply back off alittle bit and try again.Hope this helps you. Thanks
Nov 22, 2010 | Delta & Single Handle Shower Faucet
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
My Mo's shower is about 6 years old. I think the
Sure - there is always help at FixYa!
This sounds like a bad cartridge. They can be replaced. To replace the cartridge:
Turn off the water to the tub/shower.
Remove the handle cover (it should pop off)
Remove the center screw (usually phillips head)
Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
Check the cartridge bore (the hole where the cartridge was removed)
Clean any debris or scale - lime away or CLR will work
Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
Turn the water back on a check for leaks
If OK, reinstall the knob screw, and cap.
Let Mom take her warm shower...:)
Dec 13, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
How is the stem removed from the brass body of a moen single knob push off and pull on handle. I have removed the knob and chrome cover and even remove the locking pin on the shower and still cannot remove...
it must be stuck. grab it wth some pliers and give it a wiggle as you try to pull it out. and make sure the shutoffs are off or you'll get wet
Sep 19, 2009 | Home
1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
Aug 06, 2009 | Delta T13420 Chrome Classic Single Handle...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Mar 14, 2009 | Kohler Plumbing
Home Logo
527 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
