Question about Intel D865GLCLK Motherboard
Failure to go to setup or display boot devices
My laptop when switched on can only ask me to press f1 for bios and f12 for boot devices. when i press any of the two, it cant go beyond this. it only ends on loading boot devices or entering bios. this can take more than 1 hour without any result. what could be the cause?
  • 781 Answers
Try changing Motherboard battery it is probably flat
Posted on Oct 23, 2008
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
How to put a os on my aspire computer
1. Press f12 as soon as the laptop starts up. This should give you a menu which allows you to select a temporary boot device, you'll need to select your cd/dvd drive.
2. Make sure the os disc is in there, and when it says 'press any key to boot from disc', press a key.
3. Follow on screen instructions.
If F12 doesn't bring up a boot menu, then you'll need to go into the bios. You do this by pressing F1, F2 or del usually, it varies between computers. For instance I have an iBM laptop and I have to press the thinkvantage button to interupt normal startup and then select either F1 for the bios or f12 for the boot menu. But whatever you have to press, it should tell you.
Once you're in the bios then you should be able to find an option to enable a boot menu, enable it, and once you've saved and exited the bios proceed from step 1.
If you can't find a boot menu option, then you will be able to find an option to change the boot order, you'll need to change it so that your cd/dvd drive is at the top. Once that's done save and exit, then proceed from step 2. In this case, once the os has finished installing, you may want to go back into the bios and put your hard drive back to the top of the boot order, this isn't necessary but if you don't then the laptop will give you the option of booting from cd/dvd every time, thus slowing the overall startup time.
Jan 18, 2011 | Acer Computers & Internet
Whe i make power button on, he press f1 to BIOS setup utility and press f12 for temporary boot device. when i hit f1 or f12 after some minit, he display just like lock icon on screen and some times says...
Check the laptop is booting by connecting it to an external monitor and see if the lock appears there you may need to press Fn and F7 keys to switch display
If it does not, then try pressing Fn and scroll lock
Jan 10, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Zenith director laptop, after switching on the system, press F2 for bios setup and F12 for boot setup screen appears and hangs up. What to do?
If you need to boot your cd you not need to press F12 just after entering bios setting goto boot configuration and change your first boot device to cd\dvd and press F10 and select yes.
Dec 08, 2010 | Computers & Internet
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentre® M55-8810 PC Desktop
IBM T30 2366-FBU, will not boot passed Logo screen
Press all of the function buttons one at a time until you get a response. Not all laptops use the same buttons for Bios and choosing the boot device.
Also, it won't boot from the CD-ROM because the bios boots from the Hard drive first by default. You can change this in the BIOS.
Please rate, Thanks!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
Hardware problem - not booting into windows
tosrisri hello,
If you have a VISTA DVD, please insert it, and use the BIOS to boot through your CD.
Then, when the VISTA installation comes up, press repair. Restart, and try again. Please report back.
Aug 09, 2008 | Lenovo 3000 C200 Notebook
Intel D865GLCLK Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
