How to turn off key lock on E-motion - Televison & Video
Door key will not open door
Will door key insert into lock cylinder? Usually exterior door lock cylinders may seize due to lack of use if using the key fob. You can use WD-40 and insert the straw into the lock and spray liberaly. Use the key in a sawing motion while applying turning pressure on the lock. This will normally free up any seized/sticky wafers in the lock assembly
Dec 29, 2015 | 2000 Mitsubishi Montero Sport
How to open 2005 honda accord trunk release not working
If release lever is not functional, use key. If key will not turn in cylinder, spray WD-40 into cylinder and use sawing motion to get key inserted and continue sawing motion to free up lock wafers internal to cylinder so it will turn with key. If this process is not effective, you will need to remove rear seat to access paneling to trunk lock and open accordinly
Dec 21, 2015 | 2005 Honda Accord
How to open doors on 2000chevy malibu battery dead?
The outside door locks/trunk lock will most likely not work due to the key not being able to be inserted/turned in the lock cylinder due to lack of use. Spray WD40 into door lock cylinder using supplied straw and insert key until it goes all the way in using sawing motion. If lock cylinder still will not turn continue sawing motion with key while holding gentle turning pressure on the key. This will usually free up any sticky/seized lock cylinder wafers and allow the cylinder to turn
Nov 29, 2015 | Cars & Trucks
2000 maxima key will not open driver side door
Spray some WD-40 in the key hole and use the key in a sawing motion while gently trying to turn the lock. This will usually free up any sticky internal lock wafers and get the cylinder back in operation
Nov 15, 2015 | 2000 Nissan Maxima
Key will not open chev. hhr 2009?
Most common issue is a worn key but it could also be the tumblers inside the lock cylinder. I would get new key made at the dealer using the key code.
Oct 06, 2014 | 2009 Chevrolet HHR
Ignition lock stuck
You mean the ignition, not the fob. Right? Ok ; mine does this too -- use a little WD40 in the key slot, or graphite. Don't force the key to turn but give it a minor up/down motion when trying to get it to turn.
Sep 08, 2014 | 1999 Volvo V70
Car has gone into freeze mode. Can't turn key, start engine, change gear or turn wheel. Have tried with foot on the break but still no go.
it sounds like you locked the steering wheel. usually trying to turn the wheel a little in a clockwise motion while turning the key to the start/run position works.
May 02, 2014 | Mitsubishi Colt Cars & Trucks
2011 road glide steering locked can't release What do I do?
Hi Anonymous, try pulling hard left in a rocking motion at the same turning the key. Good luck
Nov 17, 2013 | 2011 Harley Davidson FLTRUSE CVO Road...
Ignition key will not turn, says push something
steering wheel is locked it sounds like. turn the wheel in a side to side shaking motion while turning the key
Dec 10, 2010 | 1995 Honda Accord
I put the key in the starter and the steeringwheel doesnt move and its locked
the key may be worn out
you will need lots of patience
try to turn the key and move it up and down motion, at the same time rock the steering wheel back and forth slightly
after you get the key out, try to get another key cut with the VIN number or have the lock cylinder repair or replace
good luck
Mar 09, 2010 | 1994 Toyota Camry
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
