Question about Dyson Ball HEPA Upright Bagless Vacuum - Iron/Satin Yellow
Dyson ball bar wont spin
My bar on my Dyson ball has just stopped spinning ? It has always worked ok apart from this Thanks in advance Leigh
  • Official Brand Answer
  • 2,572 Answers
Hi Leigh,
I'm sorry to hear you're having difficulties with your DC25. This machine has a sensor which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from the brushbar, you should be able to reset the machine. The easiest way to do this is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
The video below may also help. Following these steps should resolve the issue, but if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
[unremark-end]-->
Posted on Feb 23, 2012
  • AskDyson
    AskDyson Feb 23, 2012
    Unfortunately the video in my previous response has not embedded correctly - you can find it here:
    http://www.youtube.com/watch?v=q--faamcC...
    Best wishes,
    Jack
SOURCE: Dyson dc15 ball/ taking apart
The Dyson site has a help section where you can read how to take the unit apart to unblock it. Maybe your solution can be found there.
Hard to tell since you didn't say what the part is.
Posted on Oct 30, 2008
ThinkVacuums
  • 144 Answers
SOURCE: I have a Dc-25 Dyson ball,The beater bar does not
check to see if the belt is broken or loose and have a technician look at the clutch to see if its burnt out.
Posted on Oct 23, 2009
Testimonial: "it was somethimg simple, the wheels were'nt releasing. thank you. Bruce"
VacuumRepair
  • 438 Answers
SOURCE: The bar isn't turning on my Dyson Ball vacuum.
Greetings from GoVacuum,
The Dyson DC15 Ball is a two motor upright vacuum. Most other uprights use just a single motor that controls the suction on one end, and the roller brush on the other end.
The Dyson however is different. The DC15 has two motors, one dedicated to suction, the other dedicated to running the roller brush. You should first check to make sure that you in fact have turned on the lower motor for the carpet setting. There are two switches right next to each other, one is for the suction, the other for the roller brush, make sure both switches are turned to the on position.
If both are in the on posistion, and the brushes still don't come on, the machine also has a reset switch for the lower motor. This is here to help protect the belt from burning if something gets stuck in the vacuum while it's on. There is a little red reset button on the top of the roller brush housing (I believe on this model it's on the left side of the brush if you were vacuuming), try pressing this red reset switch.
If neither one of these suggestions fixes your machine, I would personally return the vacuum to where you bought it. There's no reason that it should not work right out of the box, and this may mean that the machine was damaged in shipping.
If you'd like some further help, please let me know by entering a clarification request to these suggestions, and I'd be more then happy to try and diagnosis this further with you.
Was this helpful to you? If so, please be sure to rate the repair tip as helpful, this will help me out a lot. I really appreciate it.
Chris J.
GoVacuum
Posted on Mar 20, 2010
Testimonial: "Was having problem with brush working, your info was very helpful, however, I might have to take it back. Still isn't working. Thanks so much! "
Dysonteam
  • 167 Answers
SOURCE: dyson ball dc24 the brush bar is not turning
Hi its Darran at Dyson.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning.
If this doesn't rsolve the problem, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Posted on Apr 22, 2010
My dyson dc25 brush bar will spin for a few seconds and then stops. What can I do to repair myself? The brush bar is not jammed, it spins freely by hand.
if it spins freely no resistance you probably need a belt..
http://www.vacuum-direct.com/dyson-dc25-drive-belt.aspx
if the belt is ok then the gears may have striped ck amazon for a head assembly complete.
Jan 28, 2018 | Dyson Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dyson DC25 Broken Brush Bar Connector
    Hi Alex, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC25. If the drive spindle of your machine has broken in use, you would need to replace the cleaner head assembly.
    Please get in touch with us directly, as our experts will be able to take some further details to confirm if we're able to replace this for you under the terms of our 5-year warranty. You can reach us by emailing askdysonUS@dyson.com
    Best wishes,
    Jack
    www.dyson.com
    May 19, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    I have a Dyson Ball vacuum cleaner and slowly the spinning portion of the vacuum ceased to work. We checked for hair, etc. that might be caught but it is all clean. We also checked the filter within the...
    Hi Antonia. I assume the spinning part is the brush roller. If so, you have a broken or stretched belt. I am not too familiar with the Dyson. I would be interested to know your progress so I can learn also. Thanks Chris
    Feb 09, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Hello! Help!! The brushbar on my dyson ball vaccuum will not spin. I took out the brushbar and cleaned it, then reset and cleaned out the filters too but still doesn't work. Do you think I need a new...
    Sorry this is not a solution. But after reading your problem and other people with the same problem, i just wanted to say i have a Dyson DC24 ball and have only had it 1 year and the exact same thing has happend it is spotless inside and out including the pipes and brush bar, still no matter how many times i press the reset button it still wont spin. I am going to go back to a Hover because im fed up with this piece of **** Dyson! sorry but wasnt there a time when things where built to last! I am now using an ancient Hover junior which is the spare vacume cleaner we keep in the cupboard. Dyson LOL.
    Jan 01, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    My brush wont spin
    hi hckymom. when the brush won't spin it is almost always because the belt is broken. Dyson requires you to buy a new drive belt assembly. Easy to install but expensive....usually about 70 dollars. Joe
    Thanks for choosing Fixya!
    Dec 13, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    Brush stopped spinning
    If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
    Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    Brush does not spin all the time
    HighnTools posted this solution a while ago. This might be related to your problem:
    I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
    The above was from HighnTools.
    May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
    The brush bar wont spin on my dyson dc 25... i
    Kind regards
    Darran
    Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
    Dyson Brush Bar Always Spins
    Take off the brush cover and check that the suction orifice is clear. Also check the rubber flaps at the bottom of the hose/handle holder is correctly positioned.
    Feb 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dyson Ball HEPA Upright Bagless Vacuum - Iron/Satin Yellow Logo
    83 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
