Question about Honeywell Heating & Cooling
What is the wiring diagram for the Honeywell Aquastat controller? The ZR and ZC wires on a diagram. Which wire is power for burner . and there is a fourth wire . what is that?
refritech08
  • 149 Answers
SOURCE: i have a gas fired
which colors are they? one should be from the igniter that goes to W on the thermostat and the other goes to Rc just make sure that the one from the igniter goes to W
email me if you need additional help hvac.tech7872pr@gmail.com
here's some additional instructions if you need them:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2104ES.pdf
Posted on May 05, 2008
SOURCE: how to wire a aquastat
don't waste my time
Posted on Aug 31, 2008
SOURCE: Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Posted on Sep 18, 2009
SOURCE: Old system has a 6006
Hello The easy way to bring the blower on for heating is if the thermostat has an ELECTRIC heat function or selector switch.That will bring on FAN during a call for heat.The aquastat won't be used.
Posted on Sep 08, 2010
shastalaker7
  • 1515 Answers
SOURCE: The instructions say the Honeywell
This Honeywell control thermostat is made for wireless control, by means of a relay control transmitter with a range of 30 meters. It only needs a 2 wire connection on this stat if indeed it is the DT92E stat. Even though the diagram shows three, you will need only 2 for operation. This is a fact. I have done some reading on this model and many of its relatives, so with built in relays, and transmitters, this is an amazing set-up. Good luck with it as you should enjoy its operation and user friendly features.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Please be kind when rating, as I know you will be. If you have anymore questions, leave them in the comment box so I can check in when I can get to them. Thank you for using Fixya.com
Posted on Nov 20, 2010
Which contacts do I connect the boiler to? I thought it was the TT, but I am not getting any voltage on them.
Here is a link, that includes the wiring diagram:
http://www.forwardthinking.honeywell.com/related_links/water/aq2000/install/69_1974.pdf
It looks like the 'T-T' terminals match up with 'T-T' terminals on the Boiler Aquastat-- Do you see that control?-- and do you have wires between those controls.
Power to this Control Module is all the way to the left on the connector terminal board-- the ones that say:
R (1) C (2) - Power In
Also: Did you realize that this control is a modulating control-- Not just an 'On-Off' control?
This control has outdoor sensors, that modulate the temperature of the water temperature-- The warmer it is outside, the lower it sets the Hot Water Temperature-- thus saving fuel-- yet assuring that on very cold days, you still get Hot enough water to be comfortable in your occupied space.
Oct 12, 2013 | Honeywell AQ25142B Aquatrol Boiler Reset...
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
I have a Weil mcLain Gold gas furnace and the Amtrol WH-7L hot water maker. I heat alot with an indoor woodstove and if the furnace is not being used I cannot get any hot water. However, when the furnace...
You should download & review the manual for Amtrol Boilermate products here.
Page 12 of the manual begins examples of wiring between the Boilermate and aquastat (also gas valve and multi-zone relay), that is usually mounted on the boiler. In order to use it correctly, you'll need to determine which aquastat (or other device) your furnace has. You should be able to locate this info on the inside of the aquastat cover. The Honeywell Triple Acting aquastat is very common and looks like this:
The cover is held by a single screw on the top, bottom or front (depending on the model you have). The inside should have wiring information along with the model number. Compare the model number with the wiring diagram for it in the Boilermate manual.
Make sure power is OFF before continuing.
Check that all wires are terminated and undamaged. Make sure terminal screws are not loose. Tighten any found to be loose.
The orange wires are connected to a switch that is normally OPEN but CLOSES to start the boiler when the hot water has cooled. It is also used to operate a "power vent" for a minute or two both before ignition and after flame out for safe pre and post purging of the combustion chamber of furnaces that lack a chimney.
Blue wires are connected to a switch that is also normally OPEN but CLOSES to start the boiler when the hot water has cooled. When the switch connected to these wires is CLOSED, ignition happens instantly. There is no delay for purge so when these wires are used to start a furnace, it should be one with a chimney - not a power vent.
For additional help with your particular installation, you will need to provide information concerning the wiring diagram in the manual that applies. Otherwise, there are simply too many variations to walk through.
I suspect that the switch(es) that are connected to the orange (or blue) wires - or the device (aquastat or multi-zone relay box) is not operating as expected to start the furnace.
The troubleshooting section of the manual that seems to apply best is the section: Boiler will not operate when calling for hot water on page 27 (if you want to try some of their suggestions while waiting for additional replies).
I hope this helps..
Nov 29, 2012 | Heating & Cooling
Utica Boiler model # MGB100HD with a Honeywell Aquastat Relay model # Type L8148E will not operate the circular pump. THe damper works and I can hot wire the circulator pump but it won't turn on...
how did you hot wire it. did you jump the wires on the relay board or use another power source? Does the boiler burner start? Have 120 volts incoming to the relay board? You hear relay click when turning power on/off? If so bad relay, or loose wiring terminals on the board. This control has built in transformer that can burn out, that will stop the pump relay contacts from working.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
Looking for simple wiring diagram to wire ******** aquastat
What are you fanning??? the fire?
Do you have a circulator that circulates when the water is up? Many controls have a AUX connection ... wire the AUX to your fan --- alaternatively, wire directly fron your circulator connection to the fan.
I hope I understood your question ...
Let me know what happens.
a
Oct 16, 2009 | Honeywell International Honeywell&...
How do i install a zone valve in my hot water heater. I need the schematic from boiler controller to the valve. if I tie the first floor to one valve , the rooms (2) will be on the last section before the...
The two zones have seperate supply and returns, correct? If not zoning will not be possible without piping the system in that way. Assuming the piping is correct, for two zones, you will need two zone valves, one cut into each zone. The wiring will vary, but for a 3 wire zone valve, (Taco), power from the transfomer goes through the thermostat, into terminal 1 on the Zone Valve, Terminal 2 on the zone valve goes back to the transformer, (24v common), and also to one "T" terminal on the aquastat (boiler control), and Terminal 3 on the zone valve goes to the other "T" terminal on the aquastat.
For a Honeywell, or other motorized Zone Valve, power again goes from the transformer, through the thermostat and into one side of the motor contacts/wires (depending on brand), the other motor wire goes back to the transformer, (24v common) Then the two end switch contact/wires go back to the T T terminals on the aquastat.
If you are using motorized zone valves, and only 2 of them, the transformer in the aquastat will be strong enough to power them.
Hope this helps
Jul 04, 2009 | Kenmore 75944 Gas Dryer
Boiler will not shut off
boiler does not shut off when thermostat reaches temp, i already replaced aquastat but condition still exists
Nov 14, 2007 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
