Question about Whirlpool Kitchen Ranges
Whirlpool Wall oven Model 6AKP124WH Oven switches off when cooking time has elapsed but fan continues to run when timer reaches "0"
SOURCE: electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Posted on Jul 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave oven
Yes, it could be. The first thing to try is a "hard reset".
Unplug it from the power line for a few minutes, plug it back in, then try again.
Let us know if the hard reset doen't fix it.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool gas oven shuts down after cooking for extended periods
id like to see it happen bfore replacin parts, but the control panel is the only "control for bake" there is no "resetable thermostat", and it uses direct spark , not an ignitor( usual suspect)..perhaps after long heating the relay on the control heats up and doesnt close correctly
Posted on Jan 20, 2009
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
freetek
  • 5568 Answers
SOURCE: Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Posted on Aug 18, 2009
Testimonial: "Very helpful. I may actually be able to take care of this."
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
Why does the cooling fan on the oven continue to run?
Never heard of a cooling fan in an oven.they are usually used for fan baking, which speeds up cooking.
Sep 19, 2014 | Ovens
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
I've read the "getting started" instructions regarding the auto matic switch on and it doesn't seem to make sense. I can get it to turn off automatically but not on. Sorry for being dim.
Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time.
Hope this helps
Feb 21, 2013 | Neff Ovens
The vent fan on my over the range Whirlpool microwave (mh1150xmq-0) runs any time I use the microwave (as if I have turned the vent fan on "low"). This doesn't seem to affect cooking, but it...
You either have a shorted exhaust fan thermostat or a shorted fan relay on the control circuit board.
While we regularly repair these controllers by mail for $39.95 postpaid with a one-year guarantee, or you can order a new control circuit board (part number) from the Pros here, we strongly suggest that you or someone you know check the exhaust fan thermostat first.
It should read "open" on a continuity (ohms) test. If it reads closed (shorted) it is bad and the fan will run all the time.
Or you can simply unplug the oven's power, disconnect one lead from the thermostat, tape it over to prevent shorting, then plug the oven back in. If the fan still comes on, the problem is on the board. If it does not, the thermostat is shorted.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 14, 2011 | Whirlpool MH1150XMQ Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
Electric oven fan
Aug 21, 2006 | Smeg A1A.1 Gas Kitchen Range
Kitchen Ranges Logo
187 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
