Question about Troy Bilt 5.5hp Self Propelled Mower
Troy-built series v560 won,t stay running and is hard starting with no primer button on it. what is the problem.
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
MOTORWIZJ
  • 1338 Answers
SOURCE: engine doesn't stay running
99% ITS WATER IN THE GAS
Posted on May 21, 2010
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
New primer bulb but engine won't prime
remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Apr 26, 2013 | Garden
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Primer bulb does not work
if you have gas in the primer bulb its working. gas is sucked from tank to carb , out return tube to primer bulb and back to the tank from the primer bulb. most likely dirt in carb or hard diaphram not opening needle valve allowing fuel to be sent. carb kits are around 12 bucks . but carbs for troybilts are usually only 20 bucks. I would just replace the whole carb if the case. if the bulb stayed empty I would look for broken fuel line in the tank that holds the fuel filter. they rot and break off within a year or two.
Apr 20, 2012 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Not drawing fuel into carburator.
The primer button draws fuel into the carb. Once started the carb acts like a fuel pump and draws in fuel on its own. It sounds like the carb needs a new diaphram. It's not that hard to replace if you are a do it yourselfer. Just watch where the fuel lines are hooked up to.
Apr 22, 2010 | Garden
I can start it, but it shuts down after a 10 seconds
The model number for your post is for the blower attachment. Can you pass the model number of the upper assembly please so we can better help you. Thanks
Kelly (cont below)
I am going to go out on a limb here.. Most of these troy-built trimmers use this carb with primer bulb.
PN 753-1225
http://www.ereplacementparts.com/carburetor-with-primer-p-283336.html
What usually happens to them is the primer bulb on the bottom of the carb gets a pin-hole in it and then air is drawn into the carb vs fuel from the tank.
You can try to get just a primer bulb at your local lawn mower parts supply. You may just have to bite the bullet and replace the whole carb.
Apr 19, 2010 | Troy -Bilt String Trimmer/Blower...
When I try to use the primer bulb there is no air
check your filter and lines. one may be broken, also your primer may be bad replace it and any bad lines you find
Oct 17, 2009 | Troy Garden
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt 5.5hp Self Propelled Mower Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
