Question about Gear Head WC535I Webcam
I installed the driver but it says its disconnected
Acer S232HL driver did not install I want it instead of the Generic PNP driver. Help please
Good for you Barb, in the future be aware the for display adapters you can simply remove them and you would be prompted to re-install a driver for it at reboot.
It will by default use a generic monitor driver so you just cancel out the install and then run the setup off the CD.
regards,
Mike
Oct 07, 2012 | Acer S232hlAbid 23 LED LCD Monitor 2 ms...
Message says generic error
Reinstalling the latest driver for your scanner should correct any software related issues.
You can find the drivers for your scanner here: Drivers V 4.2.2.2
1. Download the driver and save it to a folder on your desktop. You will then need to right-mouse click the file and EXTRACT the installation files. Do not run the installation with the scanner connected.
2. Turn off your computer and disconnect the scanner.
3. Restart your computer with the scanner disconnected and run the scanner installation program found in the folder, usually SETUP.EXE. Follow the prompts. Do not reconnect the scanner until prompted to or the installation ends.
Please be aware that the scanner installation file is 118MB and may take quite a while to download depending on your internet connection.
Happy Scanning, Myridom
Mar 05, 2011 | Plustek OpticBook 3600 Plus Flatbed...
This Scanner did not install driver. I need to install mustek scanner 1248ub driver. Software completely install but Driver didn't install.
Disconnect scanner from computer, uninstall the software you installed and restart the computer.
Download the latest driver software from: http://www.mustek.com/mustek/Support.php
Install the driver software but do not connect the scanner until the installation prompts you to connect it or when the installation is complete.
I hope this helps. Good luck!
Jan 30, 2011 | Mustek Scan Express 1248UB Flatbed Scanner
Trying to install the driver and the download will
Hi!
Don't forget to disconnect first your printer from your computer before installing the software for your printer...
If possible upgrade first the driver of your usb to 2.0 or latest version. try also disconnecting plug and play hardwares that may be using your usb port..
Hope this help you..thanks..
May 26, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Airbag deployed
SECTION 501-20B: Occupant Restraints — Passive — Supplemental Air Bag System 2000 Villager Workshop Manual REMOVAL AND INSTALLATION Module —Driver Air Bag Removal
syv~us~en~file=ani_caut.gif~gen~ref.gif WARNING: The backup power supply energy must be depleted before any air bag component service is performed. To deplete the backup power supply energy, disconnect the battery ground cable and wait three minutes.
NOTE: Repair is made by installing a new part only. If the new part does not correct the condition, install the original part and perform the diagnostic procedure again. If the vehicle was in a frontal collision and the air bag did not deploy, the air bag may not have been needed. Complete a diagnosis of the air bag system before installing a new driver side air bag module (043B13). Refer to Diagnosis and Testing in this section.
  1. Disconnect the battery ground cable (14301). For additional information, refer to Section 414-01 .
  1. Remove the two driver air bag module retaining bolt access covers (one shown).
  1. Remove the steering wheel bottom cover to access the driver air bag module electrical connector.
  1. Disconnect the driver air bag module electrical connector.
  1. syv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: After removing, discard the driver side air bag module bolts and install new driver air bag module bolts during installation.
    Remove the two driver air bag module retaining bolts (one shown) and discard.
  1. Remove the driver air bag module.
    1. Separate the driver air bag module from the steering wheel and disconnect the horn pad switch.
Apr 16, 2009 | 2000 Nissan Quest
Canon mp240
Go to the canon site and download the xp drivers, remove the driver
and software, clean your registry, and reinstall the software and driver.
http://www.usa.canon.com/home
Pretty good registry cleaner for free,,
http://www.ccleaner.com/download
Apr 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My comp cANT SEE serato scratch live
You have to hook up the SL1 Box or the 57SL mixer and then install the drivers. If you are not hooked up to either of these it will say 'Interface Disconnected' or 'Soundcard Not Found'.
Mar 24, 2009 | Rane Serato Scratch Live Computer DJ...
PROBLEM WITH INSTALLING ACER ORBICAM IN ASPIRE 5602 ANWLMi
disconnect the cam and restart you system and then after restarting connect back the cam and let the system detect it. and follow the installation procedure as computer appear.
if nothing work then uninstall the cam driver and restart.
and then reinstall the cam driver again(disconnect first the cam from the laptop) after installing connect back the cam and let detect again the system.
if nothing work notify me for further instruction.
Dec 21, 2007 | Cameras
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Gear Head WC535I Webcam Logo
56 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
