Question about Gear Head WC535I Webcam
I installed the driver but it says that web cam disconnected
I need a web cam installer for cdr king ao series
Good Day Anne!
I could have pointed you directly to the AO web cam installer driver that you need if you have mention the model number.
Anyways, the visit CD-R King's download site for its products, go to
http://www.cdrking.com/?mod=downloads
Scroll down below until you reach the PC Cameras category. Select from one of the AO series that match your web cam.
I do recommend you disconnect first the web cam from your PC before installing the web cam driver. You will only connect it during the installation once it prompts you to connect it.
Enjoy it!
It would be nice if you could give some ratings and testimonial to my answer.
Thank you asking Fixya.
Jun 09, 2011 | Computers & Internet
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
The pc cannot detect the webcam
I have had the same problem in the past too. Here is what I did, first disconnect the web cam from your computer. Then go to the manufactures website and download the latest drivers they have for the model webcam you have. Install the drivers first, then hook up the web cam. You should then get a pop up window at the bottom of the screen saying a new device or drivers are being installed. Once this finish's reboot (restart) your computer and your web cam should now work. You may have to adjust the settings for sound or brightness but those are minor things. If you install it the way I suggest it should work, either that or you have a bad web cam.
I hope this helps you out.
Mar 31, 2011 | Computers & Internet
My webcam not working
Disconnect the web-cam and un-install the software. Also un-install any such drivers you have installed for the web-cam. Now shut down and then restart. Reinstall the drivers once again, the connect the web-cam to the PC, if not detected have it checked in another PC, so as to confirm.
Feb 04, 2011 | Creative Labs WebCam Live!
When I try to install it says access denied.
Try see if the driver software is genuine. If not un-install the old software or any such drivers, disconnect the cam and then reinstall the drivers from the internet free support of GE.
Now you must connect the web-cam to be detected and installed.
Jan 31, 2011 | GE EasyCam Webcam
Wireless internet disconnects when web cam is plugged into usb
Drivers may be causing issue with pre-existing software. Uninstall drivers and software for webcam, then reinstall.
Update wireless driver.
Aug 12, 2009 | Computers & Internet
Driver web cam tc115 manhattan
Here is the link to the website with the install discs of all manhattan cams I have also copied the instructions for your benefit.http://www.manhattan-support.com/driver-multimedia-cams.shtml 1. Make sure that the USB web camera is physically disconnected from your computer. 2. Insert Driver CD into cd-rom drive and allow autorun menu to appear. 3. Proceed with installation by explicitly following steps 1 through 3 of the autorun installation menu, restarting where necessary. 4. Connect the USB Web Camera to your PC. 5. Allow time for Camera drivers to be detected and installed. Ignore all Windows logo certification (or similar) messages and proceed with installation. Click on Windows Start Menu and execute the Pharoah Eye software application.note: make sure the camera is unplugged before installing.That should do it good luck,
Jun 11, 2009 | IC Intracom Manhattan FUN! CAM Webcam
Acer aspire 5612zwlmi web cam and mouse pad
Mouse pad jumping can be common symptom of Synaptics pads (is it Synaptics?) - look for driver and install it.
Also, try switching it on from off and do NOT touch the pad for several minutes.
Common symptom when people just use very light pressure on mouse pad within first few minutes. Latest driver should fix.
also try pressing whole palm down on touchpad for several seconds - this can reset the software on some touchpads.
As for webcam, disconnect it, uninstall drivers, re-install drivers and then re-connect it. If it is built in then go to Device Manager - Hardware and find the device - click on uninstall driver - then re-install the driver.
Jul 22, 2008 | Acer Aspire 5610-4648 Notebook
How to download software?
Lee
Dec 30, 2007 | IC Intracom Manhattan FUN! CAM Webcam
Can't set up my web cam i need some help
Do you know the model number of your web cam? Is the computer detect a new hardware as you attach the webcam? disconnect first your webcam from PC. If you have CD utilities enclosed when you bought your webcam, then insert the disc in CD/DVD rom and install the driver.( If CD utilities not enclosed, That's the time that you force to go online. go to the website where your webcam make. search driver by inputting your cam model number. download the driver and install. ) after installing the driver, connect your cam and then let the PC Identify it. system will setup it for you.
Dec 14, 2007 | Microsoft Office Outlook 2003 for PC
Gear Head WC535I Webcam Logo
51 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
