Question about Health & Beauty
Broke tony little anti gravity massage chair with heat
Chair broke on both sides, under seat.
4 Suggested Answers
SOURCE: I need a hand held control for a HTT-9cb massage
i SOLVED THE PROBLEM BY REPLACING THE CORD ON THE HAND HELD CONTROL THAT I HAVE.
Posted on Dec 26, 2009
mvpuiu
hi, i need a cord also...where can i find one?
Posted on Dec 18, 2012
Need a control for massage heat recliner. Can't even recline the chair without it. If anyone one knows of a website to order one
Posted on Nov 23, 2013
How do you get the seat too swival on my mvp-4 hoveround power chair
There should be a lever under the seat, left side near the rear. Push the lever toward the rear of the chair to unlock the position. You may require some lubricant, WD-40, if it is stuck.
May 21, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
How to remove the seat of a prono wheelchair
Hi. To lift of the seat, you need to pull the knob under the side of the seat that allows you to turn the seat. While you are pulling upward on this lever, use your other hand to lift the seat of its mount. This might be hard to do if the seat pivot is lacking any lube or a light film of oil.
You might have to disconnect the cable to the joystick control first.
Good luck. Neil.
Aug 23, 2011 | Invacare Pronto M51 Power Wheelchair
I want to take the batteries out of the power chair, how can i do this
Flo First you have to unplug the nine pin connector at the rear of the chair and the 3 pin charger plug. Then there is a handle under the right side of the seat. Push it forward to release the pressure on the seat post. Now the hard part have someone with some strength twist and pull up on the seat at the same time until it comes off the seat post. After the seat is off then remove the plastic shroud covering the base and there you will find the batteries. Unplug the battery cables from the wiring harness and lift out them of the base. Hope this helps you
Mar 02, 2011 | Jet 3 Ultra Power Chair
I have a Jazzy 1103 Ultra and the lights are all on like it should be but the chair will not move. I am in Mississippi visiting my daughter and would love someone to help me. Thanks!
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Feb 23, 2011 | Pride Jazzy 1103 Ultra Indoor Power...
How do i remove the chair. I want to change the batteries
Bob First unplug both connectors from the rear of the chair. Then on the right hand side under the seat push the small handle forward until it stops, then rotate the seat and pull up at the same time the seat should lift off the seat post. Carefully place the seat on the floor next to the base. Remove the shroud pulling upward to release the velcor fastners and voila!! the batteries. Now if the seat is hard to pull up try twisting it back and forth to help get it loose from the seat post. You might need some help in lifting because this seat and attached parts are heavy. After replacing the batteries grease the post to help getting it off easier next time. Hope this helps you
Sep 29, 2010 | Pride Mobility Products New Pride Mobility...
Cannot get chair off. I got the Lock Know off, but chair won't move. the Bolt that the knob is attached to is still in the post of the chair.
Red You don't need to remove the bolt. If u lift the handle under the right side of the seat the seat should turn. Turn the seat a little and pull up on the seat at the same time. the seat should come out of the seat post. Also try twisting the seat as you pull up on it. If it doesn't want to come out after all that then u need to spray some WD40 or other type of oil to get the seat out of the post. They are sometimes very hard to get out cause the post wasn't greased and moisture can cause it to rust. Hope this helps you n GOOD LUCK
Sep 14, 2010 | Invacare Pronto M51 Power Wheelchair
Minor.j@sbcglobal.netLights come on. chair won't move. I hear a "whiring" sound
Sounds like you have the chair in "freewheel" Look under the front of the seat there are two levers next to the seat posts they should both be facing forwrd and not toward the sides at the wheels Your chair should now work normally Hope this helps
Aug 19, 2010 | Jet 7 Portable Power Chair
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
I need to remove driver side seat on 2009 Maxima my wife dropped a diamond from her ring and need to get access to get it out from under the seat
should be 4 bolts holding seat into floor pan, one under each corner of the seat. Remove bolts, unplug any power connections , seat should come right out.
Aug 01, 2010 | 2008 Nissan Maxima
Health & Beauty Logo
113 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
