Question about Sony MHCEC77 Shelf System
When i turn my stereo system on it 'CLICKS' then goes off.
Changed car battery and the dual car stereo won't work now. reset the stereo and the security light is flashing and the stereo still won't work?
Your solution depends on the brand and model number of your stereo system I take it your stereo system is Ruth is included in a anti-theft device this is highly technical and manufacture specific you need to follow the instructions for installing the system initially somehow your system lost sanity. You need to unplug the fuse that goes to your stereo turn your stereo switch on and let it sit for a day then return with the users manual and go through the installation sequence that has to do with connecting power and setting default settings other than that you have to contact the manufacturer
Nov 25, 2014 | Dual Xdma6540 Car Stereo Receiver
Car stereo problems
Do you have an amp? Remote wire might have come loose and the amp is telling the speakers to stop playing. Or, you might just have a setting problem, like it\'s turned on to just the rear and the rear is set to sub. Try dinking with the settings and running flat eq....(+/- 0 on bass treb and mid). If not, then there is a master plug in the back of the system: unplug and plug back in. If none of this works, trace the speaker wires back and make sure they are connected and not melting somewhere hot.
Jun 17, 2013 | Car Audio & Video
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
After market stereo in 1997 eddie bower ford expodition provides no sound
You should be using line out from your aftermarket stereo if using the vehicle's existing amp. Then again, you may choose to bypass it, depending on the power being put out by your new stereo.
In both the Expedition and Excursion, the sound systems are different than smaller Fords. The Eddie Bauer typically had the Premium sound system, and the wiring can get tricky with those. You want to make sure it's done right so you don't short out and damage the amp circuit in your new stereo.
If all you're using is the existing speakers, then go ahead and bypass.
Feb 14, 2012 | Jensen Cars & Trucks
What is a remote terminal and where do you hook it up at
Remote terminal is on the back of stereo and goes to amp. Remote is the wire that clicks your amp on when you start your car.
Dec 11, 2011 | Car Audio & Video
Where do i connect the remote wire from the amp to??
The stereo on the remote lead, make sure its not the power lead, the remote is what clicks your amp on when you start your car. So it goes from stereo to amp
Dec 05, 2011 | Kicker (ZX750.1) Car Audio Amplifier
Panasonic SC-AK78 The stereo lights dont come on , no sound . I i I have to turn the power on & off numerous times for it to work , the lights sometimes stay frozen ,meening if i change from stereo...
This is a sign of a power supply problem. These units use what is called a "switch mode" power supply. These use a capacitor to kick-start the power supply. While I can't say for sure, this is the most likely cause. There are other components that can be close to failure later in the circuit that can cause this as well. Without seeing the actual unit and testing the circuits, there is really no way for me to know. You should expect to pay in the $20 range for parts for this repair.
Dan
Aug 18, 2011 | Panasonic SC-AK78 CD Shelf System
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
Volume turned up, kenwood shuts off briefly...
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Sony MHCEC77 Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
