Question about Lexmark X5250 All-In-One InkJet Printer
Copies have blue background - Lexmark X5250 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5200 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Posted on Feb 10, 2012
Why do I get a blue background when I want to copy an item in color?
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
May 21, 2016 | Office Equipment & Supplies
Tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 | Computers & Internet
Why when I select color copy on HP Deskjet 3050 J610, it prints with a blue background?
The issue is from the glass on the copier, it would be better if you clean it very well or possible change.
Aug 20, 2014 | HP Deskjet 3050 All-in-One J610A Printer :...
Microsoft genuine pops up and a black background
you need ot spend some money to get a legal software.
we don't do hacking here.
Apr 09, 2009 | Microsoft Windows XP Professional
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Background on my friendster
to search for backgrounds .. try
friendster-layouts.com
1. search for the desired background
ex: blue sky,skull,black.. etc..
2. now choose one of the given links..
ex: Black Layouts by Muspel . . normally its highlighted and underlined..
3. copy the css code.. ( the 2nd box below)
and paste it to your .. friendster Css ..
located in Customize profile .. 1st big box...
hope this helps.
Feb 15, 2009 | Plantronics BACKGROUND NOISE SUPPRESSOR...
DOES NOT PRINT IN BLACK
This may sound a bit dumb, but believe me as a tech support specialist, I have seen it happen. If you are trying to print a document, what color do you have set for text? I had a lady who wanted the text to be white on blue on the screen in Word and instead of setting it with a blue background and "auto" text, she set the text as white. White print on a white background (paper) doesn't show up...:-)
May 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark X5250 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
