Technika lcd32-207 keeps flashing red green blue
4 Suggested Answers
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
SOURCE: technika lcd 19dvdid-207 won't turn on. flashing red light
Try D103, usualy goes S/C!
Posted on Jun 09, 2010
  • 82 Answers
SOURCE: the blue flashing light will not stop flashing on
Had the same problem, i removed all the plugs of the PCU power suply board then replaced them all again , blue light stoped flashing, if this does not cure problem try constantly swithching on and off on power switch for a good number of times as i have been told that this some times cures the problem as it in fact trying to sort the programes out not sure if this is true but it's worth a try. best of luck.
Posted on Jan 19, 2011
After connecting my ps2 to my Technika 26" tv/dvd combo using a red, green, blue AV component cable, I still cannot find how to tune in a channel to be able to play.
With the composite cable you so not need to retune a channel! You just need to select the correct AV channel from your remote......turn on the ps2 with a game playing and select AV on remote and keep pressing it till you get the Composite channel playing your ps2 game!
Oct 19, 2014 | Televison & Video
Technika 19-228
It sounds like you are using a component video cable (red/green/blue) and either the red or blue cable is loose or broken. Most likely the blue. Check both at DVD and TV ends.
Dec 30, 2013 | Televison & Video
Technika lcd 32-207 television powers up but will noit come on blkue light keeps flashing
Hello.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Dec 06, 2012 | Televison & Video
My Technika TV is repeatedly flicking from red screen to green screen to blue screen when turned on
Tasko TV? I'm thinking the Convergance board is out. Very expensive to
repair
Aug 22, 2012 | Televison & Video
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Televison & Video Logo
Top Televison & Video Experts
