Question about Ricoh Office Equipment & Supplies
Ricoh aficio 3035 code sc992 - Ricoh Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Posted on Nov 30, 2007
spinal
  • 287 Answers
SOURCE: Ricoh Aficio 1224c
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
Posted on Apr 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
OUR RICOH MPCW2200 MACHINE SHOWS SC992-00 ERROR
SC992-00
An error not controlled by the system occurred (the error does not
come under any other SC code).
Software defective
Turn the machine power off and on. The machine cannot be used
until this error is corrected.
Re-install firmware
So try flash firmware. tell me if you need help for that
Oct 05, 2017 | Ricoh Office Equipment & Supplies
Why disappearing files from ricoh 3035 memory
The Ricoh site says 'When printing a file containing a large number of bitmap images or fonts, some of the images or font may be lost.'
You do not say if the printer is on a server or network?
Apr 26, 2014 | Ricoh Aficio 3045, 3035 Kit
Ricoh 3045 error925
Hi, mahesh Van;
The error code sc925, it mean networking problem, check up your network, will be take care this problem.
Sep 09, 2013 | Ricoh Aficio 3045, 3035 Kit
When i print A3 on Ricoh 3035 it prints a black shade on the side of the paper ,& there is no problem for A4 , please help me
Pls tell in which way you are using A4 papers. Landscape or Portrait.? More help contact me on anuruddha07@gmail.com
May 25, 2013 | Ricoh Aficio 3045, 3035 Kit
Ricoh Aficio 3035 digital
your solution in this link:-
https://www.youtube.com/watch?v=nHrs4ti3wso
Sep 28, 2012 | Ricoh Aficio 3035 Digital...
Sc992 on mp4500
The best way is to update the firmware in the copier. You have to download the current firmware and put it on a flash card and and plug it in to port 2 after powering down the copier. Power it back on and the firmware will set itself up to your copier.
Feb 01, 2012 | Ricoh Aficio 450 Copier
Please have you solution for the Error codes SC545 for Ricoh Aficio 3035 macine
fuser over/under heat u need a service engineer to reset it
reasons
1 thermistors dirty
2 thermastat blown
2 lamps blown
try resetting it 1 st
press yellow key then 107 then hold red key for longer than 5 sec
go to section 5 (mode i think) then 810 sc reset press 1 then hash key off on
Oct 31, 2010 | Ricoh Aficio 450 Copier
On a ricoh aficio CL1000N, what does the error code SC922 or SC992 mean?
There is no sc922 for the CL1000N, but sc992 is a general software error. It typically shouldn't interrupt operation, but it if it does and it happens more than once, try to figure out what you were doing when it happened. Were you printing a big job? Were you printing a job with a particular font? Does it always happen at a certain time of day? Narrowing down the conditions can help to figure what is causing the error code.
Jun 30, 2010 | Ricoh Aficio CL1000N Printer
172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
