Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Screen turned all white: I had the same problem, I reseat the cables after checking for continuity on the wires. I re-installed the system through the CD backup. The problem seemed to go away for several days. then one night on standby I could not wake it up, or so I thought, I reboot, nothing. I pulled out the battery then booted up, it went through bios then on Vista GUI screen it went white then blank. I ported the video out at the back to a HD monitor, nothing. it is not the screen, must be the video cable if not the built-in video sync. I brought it outside to see if there is a faint signal on the screen. If the FL is busted, simply nothing.. I returned it back to its package. 10 years from now Maybe I will have another problematic laptop and thus isolate the real problem.
  • 89 Answers
SOURCE: external monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
Posted on May 31, 2009
  • 7993 Answers
SOURCE: White screen problems with my fujitsu siemens
Just a hunch. If external monitor is connected to computer when computer is turned on, video output is diverted to the external monitor. Turn computer on, without external monitor, then extend your desktop to an auxiliary video screen (monitor, TV , or projector.) Or you can configure your computer to use the internal LCD and the monitor. Check the graphics properties of the laptop.
Hope it helps.
Posted on Oct 04, 2009
  • 166 Answers
SOURCE: My Fujistu Amilo laptop screen is blank, I can
Hello there,
If the backlight is out, the screen image will still show up but there is no light to shine through it so you can normally see it.
The test that I've used is to get into a bright area(outdoors on a sunny day) and angle the screen around to perhaps see any of the displayed images.... or if indoors, get a flashlight and shine it into the screen at an angle and get your face up close and move the light around the screen rather close.
This may look and feel rather awkward, but I'll say that it has served its purpose many times in the past for myself in such diagnostics.
Should it be the LCD screen that has failed, but the backlight is still working, in a darker room you'd notice the screen go from completely black to a slightly lit-up "dark gray"... which would be a noticeable change, at least, in a darker room.
As for the external monitor that you've got... I'd look into the blue 'Function-Key combination' symbols up alongside the F1-F12 keys... various laptops have a "Fn + F(1-12)" combination that will enable and output to an external monitor. Look for a blue-ish symbol that looks like two screens side by side, with a vertical bar in between them.
Alternatively, I've known laptops to just enable a secondary screen and run with it, if you plug the screen into the laptop before you turn the laptop on. Once you turn the laptop on it will duplicate exactly what the laptop is(or should be) showing.
However, i have seen Windows disable an external monitor once it gets to the login screen if it's not used to it being there - this is just to warn you that it may happen like that.
... Sheesh, also... some laptop bios's have settings that will enable or disable the use of an external monitor by default... that would be "the pits" in this case...
I hope that works out for you... follow up with any results and we'll try to go from there.
Posted on Mar 10, 2010
Testimonial: "Very well writtern and easy to understand which is a bonus."
  • 71 Answers
SOURCE: Amillo pro 2010 screens gone black tried new
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Posted on Apr 10, 2010
  • 44 Answers
SOURCE: Laptop Not booting up, Scroll Lock indicator blinking
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
Posted on May 09, 2010
When i tun on my raymarine a65 ,i get gray and white lightly shaded vertical lines. what is the problem
Check cable connections, reseat all at both ends(so say the book) Now disconnect all cables, CAREFULLY open the housing, visually check internally.Perform as a surgeon would do, reseat all connections(flex cable,wiring,IC's,& the liquid crystal LCD display) clean as necessary with electronic spray cleaner & red eraser. Reassemble. Reconnect. Good Luck.(definition of 'reseat'- unplug or move unit in socket to reconnect the components leads)
Nov 02, 2015 | Raymarine A65 Chartplotter Fishfinder...
How do I test for continuity of the gray cable on my Stairmaster 4000PT?
Testing for Continuity of the Gray Cable on a Stairmaster 4000PT
  1. First disconnect the grey cable from the back of the console and UNPLUG YOUR MACHINE from the wall.
  2. If your cable has a 6-pin round connector, you will need to check pin sockets #5 (black wire), #3 (blue wire), #2 (brown wire) and #4 (white wire) with your ohmmeter for continuity in each pin. Should get continuity from all if cable is good.
If your cable is a 9-pin cable, you will need to check pin sockets #5 (blue wire), #3 (black wire), #2 (brown wire) and #4 (white wire) with your ohmmeter for continuity in each pin. Should get continuity from all if cable is good.
on Mar 11, 2015 | Stairmaster 4000PT Stepper
Why are all the lights on LCD screen on?
How to troubleshoot and fix video problems
Here are some tips and tricks for troubleshooting and fixing laptop video problems. Video issues are very common within portable computers and with the following tips you should be able to detect and eliminate basic laptop video problems.
Laptop LCD screen has a faint image.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the backlight stays off even when you open the LCD screen or turn on the laptop. The switch turns off the backlight when you close the LCD display to save the laptop battery power. Check the LCD lid close switch. Usually it is a small plastic pin located close to the LCD hinges. Try to tap on the switch a few times to turn on the backlight. If after tapping on the LCD lid close switch the backlight stays on, you fixed the problem.
It is also possible that after tapping on the LCD lid close switch the backlight works fine, you see a normal video on the screen for some time and then the backlight turns itself off again. In this case I would blame the FL inverter board. Try to reseat cables on both end of the FL inverter to make a better contact between the cables and the FL inverter board. If it doesn't help I would try to replace the FL inverter board.
Laptop LCD screen is solid white color.
Most likely it is just a bad connection between the LCD display and the system board. I would try reseating the video cable connector on the back of the LCD screen first and check if it fixes the problem. After that I would try reseating the video cable connector on the system board. I would also try reseating cables if there is no video on the LCD screen at all.
Try to connect the LCD screen to an external monitor. If the external video is fine, you have a problem with the LCD screen or the LCD video cable. You can try to fix the problem by reseating the video cable on the back of the LCD and on the system board.
If you see the same garbled video output on the external monitor most likely it is not the LCD screen problem. In this case the system board (with onboard video) is bad or the video card is bad.
Jun 30, 2015 | Computers & Internet
My laptop dell 3541 amd makes a loud beeps on starting up till the desktop appears .. any idea to solve this issue please ?
Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jun 21, 2015 | Dell Inspiron Computers & Internet
Hi when I turn the camera on the LCD screen is white on most occasions sometime I can get a picture on it ?
The LCD has become intermittent, caused by bad screen or the ribbon cable needs to be reseated back on the systems board, because it has come loose.
Mar 13, 2011 | Olympus Cameras
Screen white
Most likely it is just a bad connection between the LCD display and the system board. I would try to reseat the video connector on the back of the LCD screen first and check if it fixes the problem. After that I would try to reseat the video cable connector on the system board. I would also reseat cables if there is no video on the LCD screen at all. This requires to take the laptop apart google the name brand and model number for a guide for taking apart.
Chris Thrash
Please Vote
Jan 10, 2011 | Computers & Internet
I was replacing my screen on the SD800IS.
Sounds like you need to also reseat the skinny ribbon cable. Believe this is the one that provides power to the backlight:
Jul 29, 2009 | Canon Cameras
Screen not working
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
Fujitsu Siemens lap top AMILO l1310G
Try reconnecting the LCD cable on the back of the screen. You have to open the screen in order to access the lcd cable.
If this won't work, the cable is most likely not working correctly.
Oct 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sidekick iD screen white
take out the battery blow it 15 times then blow the back of the phone 15 times your hardest then out the battery back into place and then the loading screen would show thats what happen to me i hope it works good luck
Mar 28, 2008 | T-Mobile Sidekick ID Cellular Phone
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
184 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
