When trying to wireless connect my laptop through my desktop pc connection fails. Have tried reconfiguration of both the 'DLINK' modem and the Laptop without success.
Try resetting your desktop back top a static configuration. ie: Do not assign a ip.
You system will assign a ip of 192.168.0.1 most likely.
Now, disconnect your modem from its power source and remove its battery for 30 seconds.
Next, disconnect your power source to the router or hub.
Now, go ahead and hook up your power connections to the router and install your battery and power connection to your modem.
Allow your modem to fully setup before attempting to go further.
Now, reboot your desktop and try your normal internet connection..
If it works ok, leave it and go to your laptop.
Leaving the desktop unit on, startup your laptop.
Your laptop should see the static address from the desktop and assign itself a different number, one that does not conflict with the ip address of the desktop.
Hope this works out well for you.
John
could i know the interet provider which u r using?????
