No picture, only sound on Toshiba Regza 37RV530U
Help! Have only had this new (not a refurb) set since mid-July 2008 and all of a sudden there is no picture.
  • Anonymous Dec 01, 2008
    It happened to me too, and I am in Iraq and cannot ship it for under about 200.00 back to the US to have it repaired. really pisses me off.
james klgr
  • 362 Answers
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Posted on Dec 14, 2007
SOURCE: No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
Posted on Jul 16, 2008
  • 53 Answers
SOURCE: I have a 2008 toshiba regza 46 lcd. somebody
Hello Reine if you can still see the picture just faded in the backround then this could be a bad connection inside your tv set that was created by the jolt because your back light is still working unexpensive to repair, if you can not see the picture anymore there could be two things that coulda happened the ccfl lamp got damaged by the jolt and needs to be replaced or the inverter power supply blew a fuse or a component and has to be repaired, what i would recommend for both cases is to take it to a near by tv repair shop and let them tell you what is wrong with your tv set if it turns out to be the inverter board that is defective they sell some online and you can replace this board on your own just be very careful when doing so, thank you have any more question just ask hope this helps.
Posted on Sep 01, 2009
  • 309 Answers
SOURCE: Toshiba Regza 42 in - have no blue or yellow
It sounds like you have a driver board problem. I suggest getting in touch with Toshiba and see if they will have it diagnosed/repaired under warranty. If not, they can give you the name and number of an authorized repair center who will know best how to diagnose and repair the problem with those units.
Posted on Dec 01, 2009
SOURCE: Toshiba Regza lost swivel stand bolts
if your GF wants you to separate the three in one coffe what well you do?
Posted on Jan 11, 2010
I have a Toshiba Regza 52XF550U which I purchased in late 2008. Recently we ditched the satellite carrier and switched over to digital OTA programming. The tv was working great getting nice HD picture...
Be sure that the setting in the TV is set to "AIR" NOT CABLE. After switching back, you'll probably have to re-scan. I'd bet that one of your connectors isn't crimped quite right. A single strand from the shield can kill the signal completely. If the center wire is too short or too long it can kill the signal. It should extend 1/16" to 1/8" beyond the threaded barrel part.
Apr 03, 2017 | Toshiba Regza 52XF550U 52 in. LCD HDTV
PAL Capability
Are there any other devices in your home theater setup?
May 16, 2008 | Televison & Video
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
Toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
Aug 02, 2010 | Toshiba Regza 46RV535U 46 in. LCD HDTV
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Dec 09, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza 32"
I would return it, sounds like the bulb died.
Feb 22, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
458 people viewed this question
Top Televison & Video Experts
