Question about Linksys WRT120N Router
Cannot connect to Wireless with my Linksys WRT120N Router.
We've had this Router for almost two years now and have never had a problem with it before but recently neither our laptop or iPod touch can connect to the wifi. It gives the prompt "Unable to Connect" when we enter in the password. To access the internet on the laptop, we've had to use a phone cord. Which obviously defeats the purpose of actually having wireless internet.
    Novelist:
  • 182 Answers
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Posted on Feb 10, 2012
  • 231 Answers
SOURCE: I am trying to connect
first go to linksys website .Find your model and find your routers ip address or Reset router by pressing reset switch on back or bottom for about 10 seconds.Once reset is done use ADMIN in log in page with no password.then set a new password.First find your routers IP address
Posted on Sep 22, 2011
  • 252 Answers
SOURCE: How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Posted on Nov 07, 2009
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
  • 70 Answers
SOURCE: I just hooked up the
Have you tried to go into the wireless section? what I suggest go into your router, and go into your wireless selection. There is connect manually or wifi protected set up,. go ahead and select the wi fi set up option,. You can then enter your pin number from said device, or if your device has a search option or a wifi protected button hit that as well as the icon inside the router menu they should synch. Hope that gives you what you need
Posted on Feb 03, 2011
puertobori
  • 7733 Answers
SOURCE: Hi, I own a LInksys
I recommend Lynksys Support and Services
Posted on Oct 24, 2010
How do I find network key for wrt120n router
You will need to check the setting of your wireless router.
Do you have any computer connected to the network?
Using one computer connected to the network, you can open the router page and check the wireless router settings.
Check this link for Linksys WRT120N router setup and troubleshooting
Oct 15, 2014 | Linksys WRT120N Router
How to setup router name & router password
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 26, 2012 | Linksys WRT120N Router
How can I assign a pasword to my linksys cisco wrt120n so i don't have to use the pppoe on my computer
if you have pppoe on your computer, you need to input your username/password on your linksys router. so that you wont have to input anymore to your computer whenever you connect to the internet.
Jul 13, 2012 | Linksys Cisco-Wrt120n Wireless-n Router...
WRT120N ROUTER TO KINDLE FIRE
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
http://192.168.1.1
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2012 | Linksys WRT120N Wireless Router
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Sep 06, 2011 | Linksys WRT120N Router
My wii will not connect to my linksys wireless router
Is it a new router? Your Linksys WRT120N needs resetting. Reset the Linksys router & reconfigure as per your requirement. I had two such routers giving trouble for the WiFi connectivity & which were new. You will be able to connect your router.
sonsunny
Jul 08, 2011 | Linksys WRT120N Wireless Router
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Is the wireless120 Router compatible with dell
Yes it is very much compatible with your XPS M140 that transmits 802.11 b & g wireless connection. In which the Linksys WRT120N Router can accept a/b/g and N wireless connections.
I highly recommend this router if you want to use one.
Jan 04, 2010 | Linksys WRT120N Router
Linksys WRT120N Router Logo
226 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
