Question about Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV
Lcd tv not work
Not back lite 24 volts ok
    Top Expert:
  • Insignia Master
  • 74,377 Answers
Hello
If there is no power light comes up, as you switch ON the Tv, the power supply board should be troubleshotted. In most cases, it will be best to replace this supply board as card basis.
lcd tv not work - 2_10_2012_7_00_43_am.jpgTwo views to your TVs power supply board is given here. It is a semi skilled work, and you must have knoledge in electronics to do this work by yoursef. The board can be bought from most of the electronics spare part selling shops at your town.
OK.
Posted on Feb 10, 2012
Screen has vertical line on left side top to bottom,tv turns on when plugged in back lights come on but no menu or display of any kind,no 12 or 24 volts
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 14, 2016 | Vizio E422VL 42 in. LCD HDTV
I power tv on it lights up for second then flicks off ,
hi look at the back of the tv, to see if you can see a light, if so the inverter is working, if you can't you will need a tech to test the tv's power supply, for voltages, you need 24 volts going to the inverter hope it helps
regards
shaun
Jan 30, 2014 | AOC Envision L27W461 27 in. HDTV LCD...
Heater wont ignite
make sure you have 24 volts ac on both sides of pressure switch if not see if fusible link is ok 24 on both sides ok see if ignitor glows when heater is turned on if it doesn't glow need new ignitor
Jan 10, 2014 | Jandy Pool & Spa
Hello, I have a Kds Radius RAD-7C monitor and the original power supply is no longer working. I have a universal power supply with a range from 15 to 24 volt and 6 amp, my question is, can I use this for...
6A is OK, HIGHER CURRENT is OK but not higher voltage, the main key is that the pwoer supply MUST be REGULATED power supply. Does it say that on the universal power supply that you have?
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 20, 2010 | KDS Radius RAD-7 17" Flat Panel LCD...
I have a Jandy Lite 2 heater and I keep getting an error message FL 0. What can I do to get this heater working?
check the copper line to the pressure switch if ok check pressure switch should have 24 volts ac both sides if ok check rest of safety circuit
Aug 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a dynex 32 lcd and in the screen has all of a sudden turned white with no picture. I still have sound but no picture and nothing is working.
open the back cover of you tv you can see the power supply there.using a multitester measure the output of the power supply wether there is 5 volts output...check the connectors specially the RGB fit them to the terminals...the power supply outputs are 5v,12v,and 24 volts if one of them is missing replace the power supply..
good luck!!hope this help you..
your rate is important to this help.tnx..
May 21, 2010 | Dynex DX-LCD32-09 LCD TV
When turned on ,nothing comes up,no picture
there is a connection between the inverter and the powersupply. on this connector there should be a line that supplies 24 volts. if you are getting that 24 volts on a volt meter the you are most definatly looking at inveters. if you dont powersupply. just a warning if you have 24 volts and the inverter doesnt work you need a new lcd panel, which is not worth buying if you can find one
May 11, 2010 | Vizio GV47LF Television
TV screen won't come up
The power supply board or inverter. The power supply board is the first step. Look for any capacitors that are puffed up. Replacing them should take care of the PS. Check to see if you have 24 volts going to the inverter. If you do PS is OK and the inverter is most likely bad...good luck
May 08, 2009 | Akai LCT2715 27 in. LCD Television
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV Logo
70 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
