Question about Black & Decker BDTF1010B Tower Fan
Ownersmanual Trying to figure how to take apart to clean
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
I'm trying to put the oven door back together and it won't fit properly. any ideas? This is a whirlpool electric range mod# RF364PXPQ.
I had mine apart to clean and could not figure out how it went back together. The side strips I thought helped hold the glass in but they dont. I then discovered the side plastic strips go back in on the flip side-inner oven side. Grrrrrrrrr...wasted half a day trying to figure this out.
Nov 20, 2010 | Whirlpool RF364 Electric Kitchen Range
Burner lights and goes out - won't heat water.
It's your water flow sensor! The gray thing inside the unit connected to the chrome inlet line. Take it apart and clean it so the propeller spins again. I had the same problem and cleaned the sensor and it works great! Good luck.
Jul 06, 2009 | Coleman Hot Water On Demand
Trying to figure out how to put back together an old 1950's Merritt and o'Keffe stove that someone took apart to clean and couldn't put back together again. It worked before they tore it apart but is in...
Good luck. I would myself try to find a general stove schematic and work out how different it is. There may be a few different rated thermostats and elements, but the bulk of the wiring pattern will be similar.
It may have to come a bit of trial and error as well.
(also, they disassembled the wiring to clean it? that's thorough!!)
Hope this helps, let me know.
May 09, 2009 | Kitchen Ranges
I need to remove my front lenses on a 1996 s500 mercedes. There is one clip on the top that I can'ty figure out how to remove. This is so i can clean the inside
these are sealed headlamps they dont come apart easy and ive seen people break them trying i have seen people removing the bulb and blowing the inside out.
Sep 28, 2008 | Mercedes-Benz S-Class Cars & Trucks
Put back togather
Well I did it. It's not exactly easy to describe. I accidently took mine apart trying to clean the roller ball and out popped the 2 springs. I sort of put it back together in "reverse". In other words, I put it together without the scroll device and then looked through the hole. By doing this, I figured it out -- when you know it's simple but to describe it without pictures is almost impossible. Mine works fine now but I don't know how to help you.
Jan 13, 2008 | Logitech Cordless TrackMan Optical...
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Black & Decker BDTF1010B Tower Fan Logo
Top Black & Decker Dryers Experts
Are you a Black & Decker Dryer Expert? Answer questions, earn points and help others
