Ducane furnace modl mpga075b3b pressure switch location
Pressure switch location
3 Suggested Answers
  • 25 Answers
SOURCE: I have a ducane furnace, the inducer motor comes
make sure the hose from vent motor to pressure switch is not plugged, put tooth pick in both end normally the fan port is plugged.
Posted on Oct 28, 2009
bigguy810
  • 448 Answers
SOURCE: my goodman furnacs says my
the limit switch tells the fan when its time to come on. when the temp falls the unit will fire up. it is a small box on the front the wire from the burner is wired to it and so is the fan pull the cover off and you will see a dile with two settings on it when the unit fires up it reaches the first mark that turnes the fan on when it reaches the recond mark the fire box shuts down the fan continues to run
un till the dile turnes back to the first mark and then the fire box comes back on un till the desired temp is reached in the house
Posted on May 02, 2011
Ducane furnace
Sensors ?
Follow the safety circuit wires to each one.Some have reset switches.
Sep 28, 2013 | Heating & Cooling
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
Ducane furnace
Pressure switch is bocked inside try a small drill bit to clean down the connection tubes and blow it out after , check hoses are not blocked or split ,
Feb 12, 2012 | Ducane Grilling
I have a Ducane MPGA100B4B gas furnace. The furnace only runs for about a minute then shut off. It does this far too frequent.\r\n First the induce draft blower turned on for a few seconds to check for...
Hello, sounds like the limit switch is opening on the furnace.Usually when a furnace goes off on its high limit is becuase the airflow is being restricted making the furnace overheat. a limit switch is there to protect the furnaace from overheating, most cuases are either dirt or the blower motor not running up to speed, anything that cuts down on the airflow will cause the high limt switch to open.
Feb 24, 2011 | Heating & Cooling
My ducane furnace gives 3 flashes which indicates pressure switch problems, low line voltage, clogged flue, but I have replace the switch, checked the flue and voltage... all are ok... what else could it...
Hello, check the small tubing that goes from the pressure switch to the inducer motor, sometimes water can drain back into it preventing the pressure switch from closing also make sure the tubing is clear of any restrictions.
Feb 01, 2011 | Heating & Cooling
Ducane high efficiency propane furnace, pressure switch problem
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
Jan 28, 2009 | Ducane 436 inch 2 - 2 burner Grill
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
