There may be a driver CD/DVD that came with the laptop. Try using that if you have it.
Otherwise, Google you laptop to find out what kind of network interface card or NIC it has. Once you find it, go to the company website and download the drivers using a different computer and put them on a USB drive. Once you've done that, transfer the file to your C drive on your laptop and run the file to install the new drivers. Good luck!
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed. rate this solution please
first of all, internet does't require lan driver...... it is inbuilt in most of the operating systems..... if your lan is realtek rtl8139ethernet nic, you can download it from http://www.realtek.com/ under quick links in the right okay???????? pls vote if you like this solution.......
hello sir,
u can access net. there is absolutly no prbl with the "Intel motherboard which has a Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC card" . u need to install first the drivers of LAN from ur motherboard driver cd. thn restart ur pc. if it has again counter a problm thn u can use any download trial version of linux drivers.
thanking u
download http://www.hwinfo.com/ this will check what you have in your system, after that download , or post me model of *********** board and go to their web site, there should be all drivers for your model
reinstall the driver for the nic that came with the laptop and it should work. If you don't have the driver you will need to download it from the manufacturer or a driver download site like drivers.com.
