Question about Goodman Tools & Hardware - Others
Goodman B2959000 Blower moter
Motor only starts by tapping the motor housing. Probably needs to be replaced. Need instructions and new part.
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
  • 1861 Answers
SOURCE: 97 4runner blower motor needs replaced. Do you
Hi. The removal is really easy; unplug the motor under the glovebox, and remove the 3 screws that holds the assembly in. You can have it out in 10 minutes.
Posted on Jul 18, 2009
  • 784 Answers
SOURCE: location of blower motor fuse
Fuse blower motor is not in the fuse box. It is located outside. lOpen the hood, on the driver side near the fender, about 1 feet from the fuse box toward the direction of the radiator, there is a retangular about 1x2 in with wire coming out from each end. Snap it open, inside is the the wire fuse.
Posted on Aug 05, 2009
SOURCE: broken piston connecting rod
The rod is cheap. If you're an experienced handymand/mechanic, it's a medium difficult job. But if the rod damaged the engine when it cam loose, the engine will have to be replaced. Need to tear it down to investigate.
Charlie
Posted on Aug 25, 2009
  • 23 Answers
SOURCE: How to uninstall a blower motor on a 1999 GMC JIMMY
Yeah if you have to tap on it, then that means the brushes in the motor are worn out and you need to replace it. The blower motor is behind the PCM and Coolant Overflow bottle. If you remove these then it will give you better access to motor. You'll have to cut around housing. There should be a groove already there for you, just make sure you don't cut all the way around it. Once you open it and get the new one installed, you'll have to use caulk to seal where you cut it at.
Posted on Dec 20, 2009
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Dayton_furnace I have a dayton furnace the blow and burners kick on and run fine, brings the house up to the right temp the burnes shurt down but the fan moter never stops blowing. what is wrong ?
Hello, if you are referring to,the blower motor then most likely the relay on tne integrated contol board is malfunctioning. Unfortunatly the whole board must be replaced in this case.
Nov 09, 2011 | Dayton Heating & Cooling
I have a Goodman GMPN furnace and the motor that runs the twin blowers has quit. How do I take it out and replace it?
If you mean the blower wheel, I wonder how you diagnosed this problem so you were 100% sure the motor is bad. I recommend to make sure of the diagnosis before spending to buy parts.
The blower wheel is shaped like a twin blade. But it's only one wheel.
However, to answer the question; Step one is turn the power off.
Then; Find the blower housing in the lower compartment on an upflow configuration.
  • Remove 2 screws on the blower housing, on the upper inside of the blower compartment to slide the blower housing out.
  • Disconnect blower motor wiring at the harness and at the control board if connected. You can cut them if you have exact replacement motor and wire nuts.
  • Slide the housing out, turning it on the side that exposes the motor.
  • Remove the 3 mounting screws holding the motor to the housing.
  • Loosen the lock nut holding the fan blade (wheel) to motor shaft.
  • Slide motor and shaft out and away from the fan blade, as they are connected together and cannot be separated. Use penetrating oil SPARINGLY.
Installation is the reverse of the removal instructions.
IMPORTANT. Make sure to leave equal space between both sides of fan blade and housing when re-installing the wheel.
Luck to you. Let me know how that turns out.
Russ
myairfixer@gmail.com
Dec 23, 2010 | Goodman GMS90703BXA Heater
Hi, My Mother has a stand up goodman in her attic that we are having problems with. The gas valve went out so I replaced it. Then the pre-vent blower went out, so I replaced it. Now it seems that the...
Verify that it has 120 volts present at the inducer motor connections. If it does then replace the motor again. If it does not then you will need to replace the circuit board.
Dec 11, 2010 | Goodman GMS90703BXA Heater
It seems the bearings on my Induced Draft Blower Motor are going out. The furnace runs for a bit then I can hear the motor seizing. It has been making whining noise for awhile but has gotten...
While you may be able to get just a motor it will not save you much. You will also run the risk of damage to the housing or fan(s) when you take the old one apart and try to install a new motor. Unless the new blower unit is several hundred dollars I would recommend you replace the whole assembly.
John
Dec 02, 2010 | Goodman B1859005 Induced Draft Blower...
How to replace heater fan moter cannot get the cover off
front main blower motor.
you need to cut the plastic housing around the
outline of the motor. the housing should have 1 or 2 small screws to hold it to the new motor to prevent excessive motor noise.
Nov 23, 2009 | 1997 GMC Safari
How to uninstall a blower motor on a 1999 GMC Jimmy? Blower motor does not work sometimes but if I beat on the blower motor housing then it will start running.
Nov 19, 2009 | GMC Jimmy Cars & Trucks
Goodman GMT115-5B, loud noise when turned on
In the lower portion of the furnace you'll see where the blower housing is hung in the center of the furnace. There are two bolts you'll need to remove to pull out the whole housing. Depending on the size furnace you have you may have to unmount the control board and set it aside. Don't worry there is no need to remove the wires from the board. Once you have the housing out set it on its side (motor side down) and you'll see a shaft where the blower wheel mounts onto the motor shaft. There should be a bolt you can tighten. first loosen the bolt and put the housing right side up. after that center the wheel on the shaft so that neither of the sides of the wheel are rubbing on the housing once you find that spot where the wheel spins without rubbing tighten that bolt on the shaft and reinstall. should the problem persist you may need to replace the blower housing and/or wheel. I doubt the motor will have to be changed.
Aug 15, 2009 | Goodman GMS90703BXA Heater
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
Blower motor 94 dodge intrepid inop
1.disconect battery
2. remove lower right undre panel silencer duct
3. remove the blower moter connector from the resistor block
4. squeeze the blower moter wiring gromment and push the gromment throw the blower moter housing cover
5. remove blower moter housing
6.romove the screws holding the blower moter down
to put back on do the steps back werds
Jan 03, 2009 | 1994 Dodge Intrepid
Tools & Hardware - Others Logo
67 people viewed this question
Top Goodman Tools & Hardware - Others Experts
john h
Paul Carew
Jeff Hogancamp
Jeff Hogancamp
Are you a Goodman Tool and Hardware - Other Expert? Answer questions, earn points and help others
