Question about Eltax AVR-280 5.1 Channels Receiver
Right speaker output gone.
I have an Eltax home theatre system and there is no output from the right speaker output. The outputs are fine for the rest of the clip outputs on the back but the right clip speaker output doesn't. One of my friends said a little bit of smoke came out of the vents once and the right speaker output hasn't worked since. Has a fuse blown or something? How can I fix this? I cannot afford to buy a new one.
4 Suggested Answers
SOURCE: Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Posted on Oct 31, 2008
  • 16 Answers
SOURCE: eltax millenium 500 speaker problem
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Posted on Apr 16, 2009
  • 1472 Answers
SOURCE: Ive just bought an eltax system, I have no
I was having trouble finding a manual on your sub as will but found a picture of the back and wanted to confirm this is what yours looks like.
If this is what you have then you have a sub for a 2.1 system. Note you can connect it to a system that has more speakers like a 5.1 or 7.1 system but you would just tie it into the front speaker.
As for the normal connection, the speaker wire connections are for the satellite speakers for the front change only. Note you can connect a second pair of speakers to make a 4.1 system. Then you would connect the speaker channel on your receiver to the "Line Input".
If your receiver does not have speaker wire connections on them (most modern ones do not have them) then you can get adapter cables at your local eletronic store. Most of them will go back to an RCA cable.
Let me know if you have any more problems or questions
Posted on Nov 05, 2010
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
I am having 21 inch onida black 200 tv .I have recently bought philips home theatre. please let me know how to turn off internal speakers of onida tv and how to turn on external speakers to send audio...
By the looks of it, the only output you can use from the tv will be using the 2.5mm jack plug headphone socket, get a cable to convert this into twin phone (red/white) for stereo sound to your amplifier. (they are very cheap £2 or so) The Home theatre system should be able to give you a psuedo surround but you wont get full surround.
May 02, 2011 | Audio Players & Recorders
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
Home theater sound from home tv
you can take those other 2 speakers and put them in the same output slots that are already being used, what i would do is toake one of them and put it in the same slots as the left speaker, then take the other and put it in the same slots as the right speaker.
Jul 04, 2009 | RCA RT2620 Home Theatre System System
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Have an existing ts-1100 home theatre infinity speakers
You cannot use this system with one that does not have a Subwoofer or LFE (Low Frequency Effect) output. Unfortunately, this sub doesn't have a line-level (speaker wire) input. Sorry.
Nov 20, 2008 | Infinity TSS-1100 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
Eltax AVR-280 5.1 Channels Receiver Logo
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
