Question about Yamaha HTR-5440 Receiver
Check sp wires?
Hi, I have had my HTR-5440 receiver for a few years and it has worked great. Lately though, whenever I turn it on, after only 2-3 minutes (sometimes in only seconds), it just shuts off. When i turn it back on it says 'CHECK SP WIRES'. I have tried reconnecting all of the wires and still does not function properly. Could it be caused by dust built up in the unit? Hope you can help. Thanks!
  • ptlady2007 Feb 05, 2009
    I have the same problem I get a check sp wires and unit shuts off what can I do
    President:
  • 3,130 Answers
Your problem most likly is not because of dust. Its a bad connection in the amp section or the protection circuit, or the speakers them self have a problem. There could also be a componet problem. Unless you know how to troubleshoot solid state electronics,you should take the unit in to be serviced. It would most likly cost more then its worth to repair. A unit this old is u replaced at this point. Good Luck
Posted on Aug 05, 2006
Why would you charge me to ask a question if you would want to know my solution for free,what,do you think i'm stupid
Posted on May 10, 2010
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
Where and how do I hook my iPod to my htr 5440 receiver?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here:
http://www.monoprice.com/products/product.aspc_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the PC's volume control for the headphone volume up. Of course, if you have a sound card with the usual green front speaker outputs that would work, too.
May 09, 2011 | Yamaha HTR-5440 Receiver
It shuts off after a few minutes and when i turn it back on it tell me to check it sp wires i just bought it today and its driving me isane
make sure wires are going where they should.pos to pos.neg to neg.any breaks in the wires?wires touching each other?
Oct 17, 2010 | Yamaha HTR-5440 Receiver
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Jun 02, 2009 | Yamaha HTR-5440 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
Remote will not work on my reciever
I am wondering if it a preprogrammed remote controller or not. If not, you have to reprogram it.
Jul 03, 2007 | Yamaha HTR-5440 Receiver
Yamaha Receiver Rear-channel Problem
Have you ever used the headphones as the sensor switch could be dirty?? Or if not mybe got a glitch in the micro from a surge or something like that. Try unplugging for a good few hours and restarting again???. Good luck Let us know as the more info we get the better we can assist you.
May 15, 2006 | Yamaha HTR-5440 Receiver
Yamaha HTR-5440 Receiver Logo
1,463 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
