Question about XO Vision XOD1742BT Car DVD Player
Radio sound goes on and off--the closest radio stations won't even pick-up. If you bump the side of the unit it will play GREAT for a short, very short time just fine then back to on and off soun
When we checked the fuse box--cleaned them all up it worked perfectly for about 2 min. then went back to the same problem. If you move the wires around under the hood--can get better then worse again. Any suggestions would be very much appreciated. Thank You, Jackie
  • 2 more comments
  • Jackie Robinson Feb 10, 2012
    Thank You Very Much...I have suspected all along that the wiring could be the issue. Do you know where I can get the wiring installation instructions? Or better yet, where I can get drawings that show how the wiring is suppose to be? Thank You!
    Jackie
  • Friendly PC Repair
    Friendly PC Repair Feb 10, 2012
    what type of vehicle is it? make/model
  • Jackie Robinson Feb 11, 2012
    2000 Ford F150
    Friendly PC Repair Feb 11, 2012
    awesome here you go :)
    Constant 12V+ Light Green/Pink
    Switched 12V+ Black/Purple
    Ground Black/Green
    Illumination Light Blue/Red
    Dimmer n/a
    Amplifier Remote Blue
    Antenna Right Front
    Front Speakers 6" x 8" Doors
    Left Front (+) Gray/Light Blue
    Left Front (-) Tan/Yellow
    Right Front (+) White/Light Green
    Right Front (-) Dark Green/Orange
    Rear Speakers 6" x 8" Rear Corners
    Left Rear (+) Orange/Light Green
    Left Rear (-) Light Blue/White
    Right Rear (+) Orange/Red
    Right Rear (-) Brown/Pink
    Genius:
  • 1,274 Answers
Sounds like you have a loose wire, what wires are you moving under the hood... do you mean behind the head unit? i'd trace each wire individually until you find one that has a poor connection, if they have wire crimps on them so you can't tell, cut them off one at a time and re-crimp them/twist them together.
Posted on Feb 10, 2012
    Thank You Again, I will let you know how it turns out after we re-do the wiring.
    Have A Blessed Weekend...Jackie
Bang olufsen beosystem 2500
This can be a problem with the radio stations itself, if its doing with all the radio stations then it must be a setting on you radio.
Jul 07, 2013 | Audio Players & Recorders
IS ONLY PICKING UP STATIC RADIO SIGNAL. ALL STATIONS
Yes you have to have an antenna. Does the car not have one originally? If you changed the radio you would have unhooked a large black wire in the back of it. Or maybe it just came unplugged. Anyways without one it won't pick up ****. Good luck
Jul 04, 2012 | Cars & Trucks
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Apr 10, 2012 | 2003 Jeep Grand Cherokee
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Jun 16, 2011 | 2002 Chevrolet Malibu
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
NO MUSIC JUST STATIC CD PLAYERS WORKS GOOD SOUNDS GREAT BUT NO STATIONS PICK UP ANYTHING
It sounds to me like the radio antenna has disconnected from the back of the radio head unit. Pull out the radio to check and see. I hope this helps, if not, let me know and ill try to assist you further
Dec 11, 2010 | 2003 BMW 325
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
XO Vision XOD1742BT Car DVD Player Logo
119 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
