Question about Fender Passport P10w Personal PA System W/wireless Mic
Fender p10w wireless system - batteries will not charge
Suddenly I can't get the batteries to charge even after several hours. I know one battery is good as it has been working lately. The unit flashes green like it is charging but never goes solid and when I do stop and turn the unit on it comes on with a red light that fades in a few seconds and then nothing. There is a black wire in the battery compartment that is lose and I wonder if that is part of the problem or is it just an extra wire? Thanks
mighty thor
  • 51 Answers
SOURCE: Fender passport model # 250 Used Only Twice!
go back in and find where the electrolitic capacitors connect to the board. They look kind of like a battery. One or both of them have broken loose from the main board, preventing any significant current from going to the output transformer, and causing overload. This is a common problem, and it does not take much rough handling to cause it.
where the break is is at the solder connection. Under a magnifying glass, the break will look like a little circle. Float fresh solder on that or any other large solder joints which may be cracked or broken.
Use standard precautions when working around high voltage.
Posted on Dec 02, 2008
  • 17 Answers
SOURCE: sounds like only one amp is working. Then after a few minutes the red light goes on and the unit shuts down.
90 % of these types of problems are caused by faulty leads .... make sure that you have correct speaker cables and not just a regular guitar cable
Posted on Feb 02, 2009
SOURCE: The 'protect light' comes on Fender PD150 Portable Sound System
The protect circuit is activated by a current sensing transformer in the *input* of the power supply. If any of the subassemblies of the unit (or all of them in combination) draw excess current then the protect light will illuminate and the power supply shut down to prevent any damage to the system.
The circuitry in the power supply is fairly robust as well as fuse protected so it is unlikely that the power supply itself has failed. More than likely one of your output power transistors has been shorted and it is easy to check this yourself if you are interested in doing so.
Furthermore if you follow a few *simple* precautions you can do this safely and confidently.
Post again on this thread if you are interested and I will spew the details.
-BK
Posted on Mar 14, 2009
  • 5603 Answers
SOURCE: We have a Fender P-250 PA system. We get the
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Posted on Sep 23, 2010
  • 5603 Answers
SOURCE: Hi I have an
Find schematics of typical guitar electronics at this site by comparing the resources if pots, pickups, etc. of your guitar:
http://www.guitarelectronics.com/c=vAvO8CR2Jt03UanFRA7IlhoRQ/category/wiring_resources_guitar_wiring_diagrams/
Posted on May 11, 2011
Fender 1270p buzzing, appears to be an internal ground problem
I would never use a fender amp without the ground plug as I have been electrocuted by doing this and could not let go. I will be wireless from now on.
Feb 16, 2013 | Fender 1270p Artist 10" 2-way...
I recently purchased a Fender Classic Player Jaguar Special HH as well as a Fender Super Sonic 22 amplifier. I noticed there is a lot of noise coming from the amp with the jag plugged in, especially on the...
"Noise" is not a very good deescription... is it hum? is it static like? is it a buzz? Hum pickup by the pickups of guitars are common and some pickups are worse. If it is hum move the guitar away from magnetic sources like amps, motors, flourescent lights, dimmers... etc. Sme guitars have grounding problems and touching them varies hum. Also, do NOT let the guitar "hear" the amp as it can feedback at frequencies above your hearing even. Do some "sniffing" by moving the guitar and the orientation around the area seeing if you can find hot spots of noise to avoid.
Sep 20, 2011 | Fender Musical Instruments Corporation...
Where can I get my Fender passport PA system services in Brooklyn, NY
Here ya go:
  • Jeff Bloch's Amp & Guitar Center 1700 10th Ave Brooklyn, NY 11215 Ph: (718) 369-7080
Authorized Fender electronics Service Center
Sep 17, 2011 | Fender Passport Deluxe 500watt Sound...
Wireless guitar system was working fine for about 2 hours & then the transmitter would have to be turned on again & again every few seconds to continue playing. this system is practically brand new...
This has the earmarks of battery problem... Supposedly this uses a 9 volt battery... You CANNOT use rechargeable batteries in these as the actual voltage of the rechargeable is lower than alkaline and they will fail quickly and as they age you may get only seconds of operation. When they go off the battery will recover a bit and even look like it comes on again. Do NOT count on the battery LED to give actual answer. When you turn on the unit, read the battery voltage under load with a meter. It should be at least 8.5 volts. NEXT possibility: A chronic problem with body packs is the battery contacts. There is a fine line between having good contact and being able to get batteries out. I have seen where people stuff paper in to increase tension on the contacts.
May 11, 2011 | Shure Distribution Shure PG14 Performance...
With the wireless mike and the 1/4-inch mike jack and the line-in from a CD-player, how can the volumes be separately adjusted?
Adjust the CD level at the CD player itself. Truly independent adjustment is probably not possible on this small system.
Feb 03, 2011 | Fender Passport P10w Personal PA System...
Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Nov 09, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Replacing the low-mid pot on a Fender Rumble 100/210 bass amp
To answer your question: YES and NO this is an easy fix.
Yes if you have the tools and knowhow, and NO if you don't know what you are doing.
There are high voltages in an amplifier that can persist even when the power is off (I have a Laney amplifier that will remain at several hundred volts for days after the power is off). There could be enough voltage stored in the capacitors to give a fatal shock.
At a minimum, you need a voltmeter, soldering iron, some 64/40 rosin-core solder, the replacement part.
Such a fix is pretty cheap for a repair shop. This is about as easy a fix a repairman can have, but thats because they know how to get in and do it without getting hurt.
I work on amplifiers and build them, and always take each time I reach into an amplifier that has had upto several hundred volts seriously. I know that I would charge no more than 1/2-3/4 hour shop time for such a fix plus parts (or about 30-ish bucks). I would think a local shop can do this for you at no more than 30-45 dollars per hour shop rate. Any competant repairperson should only take 15 minutes or so after the amp is out of the case: more time is spent getting it in and out and being safe about it with this type of repair.
Hop that helps!
-mike
Jan 13, 2009 | Fender Rumble 100 Bass Guitar Amplifier
No sound from speakers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Dec 15, 2008 | Fender Passport Deluxe 500watt Sound...
Nov 08, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Passport P10w Personal PA System W/wireless Mic Logo
157 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
