Question about Fender Passport P10w Personal PA System W/wireless Mic
I have a fender p10w but will not charge the battery after several hours. I tried two batteries and I know one has been working. .
I also purchased a a new microphone that uses better frequencies and it was working well. Now it just won't charge. Also, I note in the battery compartment a black wire that is loose; is that normal? Is it part of the problem?
2 Suggested Answers
  • 5603 Answers
SOURCE: Hello! I was recently playing
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Posted on Aug 26, 2011
Alarm goes off and won't stop when battery cable disconnected
That is because the alarm knows the vehicle is being tampered with and the internal battery takes over the alarm.
Aug 22, 2017 | Fender Music
Battery
the battery is inside the sound hole take a mirror and look inside battery should be in a clip on the side of the module control
Jul 25, 2013 | Fender CD140sce Acoustic Electric Guitar
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
HOW TO RECHARGE THE INBUILT BATTERY FOR THIS PRODUCT?
It is hard to help find a solution for you without more specific info on this. It says you have purchased this(what?) product in the 60w version and it(what?) came with no manual. I would help you figure out how to connect the battery charger(what type?) to the back(of what?) or to the wall socket. Do you turn on or off the switch on the back(of what?) while charging. AND you WOULD APPRECIATE a CORRECT answer. Please< I need you to help me understand what you are asking before I can help you. I am here to help. If it uses a backup battery like a pc, you don't charge it. If it(whatever it is) uses a battery for power, you probably plug it into the wall overnight without turning it on to charge.
Mar 09, 2013 | Music
When i turn over my fender fuzz wah i hear something rattle or clunk. Is something loose inside? I just got it yesterday.
It is probably the battery or the battery connector. Not to worry or look for the battery compartment and put your mind at rest.
Aug 06, 2011 | Fender Fuzz Wah Guitar Effects Pedal...
Can i put my fender strat mexican guitar into number two jack on the ampI got it today not sure
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
With the wireless mike and the 1/4-inch mike jack and the line-in from a CD-player, how can the volumes be separately adjusted?
Adjust the CD level at the CD player itself. Truly independent adjustment is probably not possible on this small system.
Feb 03, 2011 | Fender Passport P10w Personal PA System...
How do i change the battery in my fender strat?
In short, you don't! There is no battery in the Fender Strat.
If you are not getting output, you have a failure. FIRST check the cable by using a different cable.
There is internal wiring and the pickups, switches and volume/tone controls that can fail, however the jack is always the first suspect.
Feb 02, 2010 | Fender& Standard J Bass Artic
Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Nov 09, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender 100w twin amp no sound
Here is a test you can do at home for the sound. Test out the speaker. To do this you will need two alligator clips with wire about ft. long. Remove the speaker wire clips under the speaker magnet and attach the alligator clips . Take a C size battery and touch both ends of the battery. You should here a scratching sound . If you do you know your speaker is OK. Then you have a problem that needs a Technician. A good music shop should be able to give you a idea of the repair cost. Don't go to a big music change, find a small full service shop that deals with Fender. I don't think this will cost a lot. Fenders play for years, Its truly worth the bench fee. Good luck DFD , please rate me thanks
Apr 19, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Passport P10w Personal PA System W/wireless Mic Logo
47 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
