Question about Lorus Watches
How to set lorus yk33 digital watch
Lorus yk33 hot to set up 4 button waterproof
5 Suggested Answers
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
SOURCE: How to stop chimes on Louis Valentin waterproof digital watch
Press and hold the lower right button to display the date, then press the lower left button. If now all the weekdays are turned off, the hourly signal is turned off too. If the weekdays are turned on by this operation, the signal is turned on.
Btw: does anybody have some information about the vendor of these watches?
Posted on Feb 25, 2009
  • 2501 Answers
SOURCE: I have lost the instruction
Go to http://www.loruswatches.com/instructions.asp and fill in the details of your watch, to obtain your instructions.
Posted on Jan 10, 2011
SOURCE: how do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Posted on Jan 15, 2011
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
Set time and date on lorus digital watch
I NEED A BATTRY Y131A OR A REPLACEMENT FOR MY WATCH.
Mar 24, 2012 | Lorus Watches
Set time on vector lorus digital watch
Stand on one foot, while patting you head and rubbing your stomach... AND THEN... hold the lock/unlock button until the screen changes....the press the start/stop button which should get the seconds blinking so now you can begin to change things, switch to min/hr etc by pressing start/stop again. The orange run/rest button actually does the changing. good luck!
Dec 21, 2011 | Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
I cant set my dancing mickey mouse alarm animated rat001 watch
mcdevito75 here, The crown is very flush with the case, from the front of the watch sip a fingernail just unfer the crown and lift. Now you can turn the crown and set the time.
Jun 21, 2010 | Watches
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Watches Logo
294 people viewed this question
Top Lorus Watches Experts
ray gallant
Geoff
Are you a Lorus Watch Expert? Answer questions, earn points and help others
