Question about Zenith Z27X76R 27" TV
ZENITH TV OUT OF FOCUS
1997 ZENITH Z27X76R has gradually become out of focus. You can no longer read the CNN ticker at the bottom of the screen. I'm hoping for an adjustment on the circuit board where I can see the vertical and horizontal clearly. Where on the circuit boards is the focus adjustmet ?
  • Zenith Master
  • 6,694 Answers
You tv have problem with the picture tube base socket. After a long year of use the contacts of the base socket will become dirty. You have to replace the base socket. You can find the base socket on the PCB which place on the picture tube neck
Remove the base socket and buy a new on with the same size and fix the new one. This will solve the of out of focus problem.
Have added the picture of base socket how its look like.
Ajin
Posted on Feb 10, 2012
2 Suggested Answers
jimbo4026
  • 50 Answers
SOURCE: zenith ss2504ew9 has no vertical picture
either the vertical output is bad, or connections need resoldner at that point. Usually resoldnering takes care of it
Posted on Nov 20, 2007
When I first turn on the Toshiba projection tv the color has a strong red hue to it which clears up gradually
I would suggest when turning set on cold---turn color all the way off and examine screen as set warms up---if red to some degree but gradually becomes black and white the issue is either a "touchy" red screen control on the screen/focus block or a problem on the circuit board plugged to the bottom of the red tube.
I guess the real question is how long until it is normal?
May 20, 2012 | Toshiba Televison & Video
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
my panasonic model PT61G42V screen went flat lined and went blank still has sound, wwhat should i do?
Mar 22, 2010 | Panasonic Televison & Video
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Focus
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
also check out for the convergence bulb if that goes dim the screen becomes out of focus
thanks.
Oct 13, 2008 | Zenith SY2728RK TV
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Zenith sy2779dt
not being able to sharpen words-I cannot read words your problem is due to focus circuit. solution 1 turn focus control on flyback transformerin such a position where you get sharp image. 2 focus control wire going to crt base is loose on crt base due to foreign material drposited on it. 3 crt base loose. 4 crt might be getting weak if it is old. hope this will help. good luck.
Oct 07, 2007 | Televison & Video
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
