Question about Canon Office Equipment & Supplies
How to scan on canon mg5320 ink jet printer - Canon Office Equipment & Supplies
IB4G2008
  • 3587 Answers
SOURCE: Canon BJC 3010 Ink Jet Printer Problem
does it do a test print job?
Posted on Mar 30, 2008
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
SOURCE: Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Posted on Jul 16, 2009
komguy
  • 2306 Answers
SOURCE: CANON MP830 WILL NOT FAX OR SCAN IF ONE INK IS EMPTY
It's true, you need inks before you can scan or fax, It's not just Canon, All of the all in one machines are the same way. HP, Brother, Samsung, It's the drawback to having an all-in-one machine.
Posted on Jul 24, 2009
  • 5190 Answers
SOURCE: The ink absorber is full on my Canon IP2000 ink
The waste ink absorbers are a pair of pads on the sides of the carriage near the bottom of the printer. You need to open up the printer (pop the top off). It is just clipped into place and held by its own pressure (you can usually see how it's held in). Unscrew (if needed) the ink carriage (leave the cartridges in place) and push it out of your way.
Wear gloves and have plenty of newspaper or something handy. Pull the pads out and rinse them clean (running water works well). Blot dry or let them dry in the sun. Use a hair dryer to get the last bit of moisture out if you are in a hurry. Then reassemble the unit. Then reset the counter for the waste ink tank.
To reset the counter:
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times...
I hope this helps.
(under normal use, the waste ink absorber is supposed to register a full counter at the expected end-of-life of the printer. Additional failures may happen soon.)
Posted on May 20, 2010
My printer Conon MG5320 is not printing ink is good feeds ok but paper comes out blank
Go the the setup menu and choose maintenance. Select "print nozzle check pattern". If nothing prints again, then select "clean". Try the check pattern again and If this does not change anything then you may have to manually clean the printheads. I will post separate instructions for this if you need.
Mar 05, 2015 | Canon Pixma Mg5320 Wireless Inkjet Photo...
I have a canon mg5320 printer. I just filled 4 of yhe 5 cartridges but it still shows them almost empty, what can I do?
This is perfectly normal. Your printer has no idea you filled the cartridges. Keep using the printer - until it stops with 'ink out' error, then press the 'OK' button (on printer) momentarily. If that clears the error, you can resume printing.
If pressing OK doesn't do anything, press and HOLD the 'STOP' button for about 6 seconds - or until the error clears. This will disable the ink monitor - for the 'empty' cartridge.
You will have to repeat same process for each cartridge that turns 'empty'. Once all cartridges are disabled, you don't have to do anything - except keep refilling the ink.
You can find more info on this here: http://inkbank.com.au/webcontent20.htm
Canon ink level monitor ink tanks how to disable
Feb 27, 2015 | Canon PIXMA MG5320 All-in-One Printer
How do I get
And what seems to be the problem?
Jan 28, 2015 | Canon Office Equipment & Supplies
New black ink not drying on photos. Ink runs
Most likely you're using the wrong photo paper. Ink-jet photo paper is specially designed to absorb the ink, while copier paper isn't.
Sep 02, 2014 | Canon Pixma Mg5320 All-in-one Printer...
How do I scan a photo on my Canon MG5320?
1) Press the 'HOME' button on the top of the lid
2) Select the 'SCAN" button under the word "SCAN"
3) Use the "drop down" menu and select "PHOTO"
Jul 18, 2014 | Canon PIXMA MG5320 All-in-One Printer
Error code cooo
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 06, 2014 | Canon PIXMA MG5320 All-in-One Printer
Ink tank connot be recognized
I wish I could add a solution but I can only advise to stay away from these terrible printers. My Canon MG5320 is just barely a year old, barely used, maybe a dozen times and I'm getting an irreconcilable C000 error. "Consult the manual"? Manual advises that it needs to be seen by a tech. Same thing, can't get the cartridge tank to move to center to access the inks. It's called a built in "f-u" by Canon.
Jan 23, 2013 | Canon PIXMA MG5320 All-in-One Printer
Mg5320 no ink idicator
Sounds like the little canon needs serviced.
Jan 21, 2013 | Canon PIXMA MG5320 All-in-One Printer
Edible ink cartridges for MG5320
I had the same problem and then found out that when I removed the "tape" from the cartridge, the part that was covering a small hole on the top of the cartridge was still "covered" which prevented air from allowing the ink to flow out.
It is a very easy thing to overlook but it did resolve my issue.
Jan 05, 2013 | Canon PIXMA MG5320 All-in-One Printer
334 people viewed this question
old marine
old marine
