Question about NetGear WGR614 Wireless Router
All lights on
Hi, i have a netgear WGR614 wireless router and at some point all the lights remained on and the router stopped working. Unpluged and pluged again but didn't reboot.. all lights remained on as soon as i plugged the power cable in. Tried to hard reset it but it won't respond... no light flashing no nothing... is there something i can do to "unstuck" it?
Thank you in advance
  • 1 more comment
  • Anonymous Oct 26, 2008
    When I connect my router to my modem, I lose internet connection. Also, all the lights on the router come on and stay on. I've tried to reset the router, but all the lights stay on.
  • Anonymous Dec 12, 2008
    There is some combination of holding the reset button and unplugging the router at the same time that worked for me when i was on the phone with i am trying to fix it again and having trouble.  I would try that before buying a new may have to do it several times though
  • Toothmary Dec 29, 2008
    Netgear WGR614 All lights are on. The wireless connection stopped working on lap top. Please help
A similer thing happened to me on my old router u may need to get a new one thats what i had to do
Posted on Oct 24, 2008
I had the same identical problem. I spent two days trying to restore communications.
It was a simple simple I was kind of embarrassed to post it...well I decided that it might help others so here was my fix:
I at one point must have plugged in the wrong transformer....this causing it to keep all the lights on (except for the wireless and test light).
Looked frantically for my transformer marked Netgear...plugged it in and worked like a charm.
Hope this is your problem.
Posted on Dec 28, 2008
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Mar 08, 2011 | NetGear WGR614 Wireless Router
Netgear wgr614 v9 not working. no power light. only a buzzing noise when plugged in.
Stop using the device as the buzzing noise is likely going to be a fire hazard. You will be better off recycling the device and purchasing another. It cannot be repaired.
Dec 19, 2010 | NetGear WGR614 Wireless Router
How do I install NetGear wireless G WGR614 on my new computer because I lost my CD
Point your browser to Netgear's product support page below:
Here, you can download files, firmware and manuals. There are 11 versions of the WGR614 router - so be sure to get the appropriate info for your particular version router.
I hope this helps!
Jun 17, 2010 | NetGear WGR614 Router
Netgear WGR614 password wont work
If password is not working of router then please folow steps
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
I hope the steps above will help resolve the issue.
Thanks for using Fixya
Jun 10, 2010 | NetGear WGR614 Wireless Router
Network Key for netgear wgr614
Hi, taffy_man, the network key is something you configure yourself. If you dont know it you have to RESET the router to the factory defaults.
Take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
If that doesnt work do the same thing but first disconnect the power cable. Then while pressing the reset button THEN connect the power cable again but keep the reset button for 10 secons and then go to the or ( and do what I wrote above. Then you will have to reconfigure your settings. I hope this helps.
Apr 29, 2010 | NetGear WGR614 Wireless Router
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
My power light on my Netgear WGR614 wireless router keeps blinking & will not allow me access to the internet.I have unpluged it, pressed the reset button & the light keeps blinking.Any thoughts?
Maybe you had a power surge.
The reset button does nothing with the router powered off, basically you hold the reset button in for 30 seconds with the router powered on. Following this you will need to set up the router again as all settings will be reset to factory defaults, from the sounds of it though the router may be dead.
Another reset method is as follows;
1. With the router powered off hold in the reset button,
2. Keep the reset button in, power on the router, wait 30 seconds,
3. Keep the reset button in, power off the router, wait 30 second,
4. Release the reset button.
Did you have wireless disabled?
If you have access to a multimeter check the PSU is working correctly.
Jan 27, 2010 | NetGear WGR614 Router
Netgear Router WGR614 Problem, 1234 Lights Lit Orange, No Connect
Try resetting the Netgear back to the factory default and then configure the wireless setting.
Press the pinhole RESET button on the back of the Netgear until all the LEDs flash then connect a LAN cable from the computer to the Netgear open a browser and enter the configuration URL IP address
Jan 01, 2010 | NetGear WGR614 Wireless Router
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 V9 Wireless
yes you can detached it BUT it might affect its wireless range.
and also its not soldered on its board.
keep me posted.
Jun 17, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
534 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
