Question about Tefal Kitchen Appliances - Others
My kettle won't turn on
2 Suggested Answers
  • 27 Answers
SOURCE: Kettle won't work after switching on with no water inside
It depends on how long you switched on.
*check to make sure that the switch is transmitting electricity if not...
*from my experience with kettles you will need a new element*Depending on the kind of kettle you are using check the power cable and the base of the kettle to make that there is contact between the kettle and the power cable.
Posted on Apr 03, 2013
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Apr 03, 2013 | Kitchen Appliances - Others
Kettle keeps turning off before it is boiled
Sounds like the thermostat has gone out of calibration. If you're handy with appliance repair it might be possible to purchase (internet) and replace that part - they're usually not adjustable. Otherwise it's a new kettle.
Mar 01, 2018 | Morphy Richards Kitchen Appliances -...
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
Oct 06, 2012 | Gold Medal 2404 Funpop Popcorn Maker
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Sep 02, 2012 | Russell Hobbs Kitchen Appliances - Others
Scale between the kettle and the base?
I don't particularly know the model of your kettle. There are so many out there. It sounds like the tank is leaking.
Some of these cleaning and descale agents are very powerful and corrosive. The cleaning solutions you are using may have eaten through the tank of the kettle! This is what it sounds like to me.
Check the recommendations in the instruction manual for cleaning this kettle model.
Jerry G.
May 04, 2012 | Kitchen Appliances - Others
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 | Bosch Irons
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
Kitchen Appliances - Others Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
